Author Topic: Oil question  (Read 1975 times)
Offline Trickyboy
  • MK5 GTi 3dr Reflex Silver
Oil question
« on: 03 April 2008, 23:54 »
As you may or may not know i have a 1.8T and the oil is just above the min level, as i bought it second hand im not sure what oil is in it. Do i need to change the oil completely as i'm under the impression it's not a good idea to mix oils? Or can i just top it up with a good grade? If so what grade? Thanks from the total novice!
Offline GTi-Matt
Re: Oil question
« Reply #1 on: 04 April 2008, 07:53 »
how long have u had the car? when was it last serviced? id service it now and i think the oil for a 1.8t is 10w-40 or could be 5-40.
5-40 is what i use in my 2.0l
hope this helps.
I must warn you I'm about as decisive as a 5 yr old in a sweet shop!!  :grin:
Offline Trickyboy
Re: Oil question
« Reply #2 on: 04 April 2008, 16:31 »
Ha dthe car about a month, the thing that worries me is it was last serviced just before i got it and it's needing oil already!?
Offline Trickyboy
Re: Oil question
« Reply #3 on: 04 April 2008, 16:38 »
And if i do need to change what type would be best?
Offline richw911
Re: Oil question
« Reply #4 on: 04 April 2008, 18:41 »
Can you find out what thay put in last time??
Castrol magnetic 5/40 but 10/40 will be fine.
Get the oil filter from vw you will find thay are cheaper than elsewhere (Well thay are in devon lol!)
If you can find out what grade is in there just top her up will be fine - just keep an eye on her  :wink:
Offline Trickyboy
Re: Oil question
« Reply #5 on: 04 April 2008, 18:44 »
nah, can't find what they put in last time unfortunately. Ill just keep an eye on it, got no warning lights at the mo so thats good! Ill buy the oil and filter if i need to and take it to my local mechanic to do. Aint got no tools!  :embarassed:
Offline richw911
Re: Oil question
« Reply #6 on: 04 April 2008, 18:51 »
Sounds like a plan! How have you been driving - hard? Its normal for turbo engines to use some oil especially when being driven hard  :smiley:
Offline techie
Re: Oil question
« Reply #7 on: 04 April 2008, 18:56 »
4.4 litres of oil FYI when doing an oil and filter change.
MK2 Golf GTi (Built with bits from MK2, MK3, Mk4, Corrado, Ibiza Cupra and Audi TT, a truly VAG car indeed.
Offline Trickyboy
Re: Oil question
« Reply #8 on: 04 April 2008, 18:58 »
Well i went from a lupo 1.4 to this beautiful driving machine so at first yeah! You could say "screwing" would be the appropriate adjective! ha! calmed down a bit now though so im gna have another check tmrw and see how its looking. Thanks for the advice!
Offline richw911
Re: Oil question
« Reply #9 on: 04 April 2008, 19:05 »
No probs  :smiley:
