Author Topic: need more charge!!!!!  (Read 3741 times)
Offline 1300mk2
« on: 14 April 2004, 22:30 »
would it be sensible to up the gauge of the alternator wires and battery earth in order to stop my batt going flat, or would a gti alternator be a better option?
Offline Dizzie
  • Make friends with your fast
Re:need more charge!!!!!
« Reply #1 on: 15 April 2004, 00:06 »
go get a passat or audi alternator from le scrappy for ?10 in 90Amp flavor. That'll sort you out ;D
(polish it before putting it on. save you doing it later ;))
Mk4 Golf 150PD
Offline davidhawkins_78
  • Valver Bad Boy
« Reply #2 on: 15 April 2004, 09:17 »
Before you spend a pennie you need to look in to why it's going flat as I'd say it's a fault somewhere - how have u got your Headunit wired up as this is the most common mistake!
Early Golf's never came with a remote live, plus it's easy to get it wrong and there's a trickle charge coming off the battery 24/7 ....
'89 Monza Blue Valver
to quote a VW engineer, "the Mk1 was the prototype, the Mk2, the real thing!"
Offline paladin
  • Call me old and I'll smack the sh!t out of you.
« Reply #3 on: 15 April 2004, 20:34 »
I agree, before jumping the gun, make sure there isn't too much draw when the car is off.  Then test the battery, if it's over 4 years, it might be on the way out.
If all your mods have brought up the draw (while running) then a Mk3 (90amp) from a junkie might indeed do the trick.
'94 Mk III 2.0
Bosal cat-back:K&N w/mod.airbox:GIAC
Alpine 9815
JBL BassPro
CDT Audio HD-52 in reinforced q-form kicks
MB Quart 218.21 (mid's) in rear
QuietCar (being applied)
