Author Topic: Mk 3 Amp cable?  (Read 1887 times)
Offline Bootneck
Mk 3 Amp cable?
« on: 02 April 2008, 20:45 »
Had a look under the bonnet of my Mk3 8v GTi and can't see anywhere obvious to run the power cable through for my amp,anyone able to help? Cheers
Good Advise is something men give when too old to set a bad example
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
Re: Mk 3 Amp cable?
« Reply #1 on: 03 April 2008, 10:18 »
There is usually a gromit somewhere in the bulk head you can use. alternately you can drill your own hole. just make sure you seal it properly if you do.
 :smiley:
Offline Bootneck
Re: Mk 3 Amp cable?
« Reply #2 on: 03 April 2008, 10:20 »
I can't be trusted with a drill,me a sharp objects don't work together too well. I pull the carpet out on the passenger side maybe something will be more obvious from inside.
Re: Mk 3 Amp cable?
« Reply #3 on: 03 April 2008, 10:37 »
Im sure youd be fine.
There is a gromit somewhere there, just cant remember where it is. if your that bothered, run the cable down the bulk head and under the car. come up through a gromit in the boot.
 :smiley:
Offline boneybradley
  • Back in a Mk3...
Re: Mk 3 Amp cable?
« Reply #4 on: 03 April 2008, 13:04 »
If yours has the same factory alarm as mine..there's a grommit on the passenger side bulk head (below and to the side of the abs pump) where the alarm wires run through.. i modified this grommit to thread my cable
Offline Bootneck
Re: Mk 3 Amp cable?
« Reply #5 on: 03 April 2008, 15:16 »
Job done now,got my amp wired and running a suitably Old Skool sub for a '94 Golf,Rockford Fosgate 10 inch Bass Tube,Proper Old Skool :laugh:
