Author Topic: Headunit probs - any ideas  (Read 3062 times)
Offline Humph
« on: 02 April 2008, 19:55 »
Hi All
Just fitted new head unit (JVC KD-G341), but it doesn't seem to be working.  :angry: Before I send it back, thought I would ask if I am missing anything obvious. It is fitted to a MK2 16V.
When I turn ignition on, you can here it fire up for 4 seconds then it goes off. Press the CD eject button it comes on, takes CD in then switches off again after 4 secs. Press button again and CD comes out. Press display button, shows clock for 4 secs then goes off again. Press the power button and nothing happens.
I have pressed the rest button, with no effect - any suggestions, or is it a duff unit...
Humph
MK2 16V GTI
Offline S11EPS
  • No golfs here. Only a C63 mercedes
Re: Headunit probs - any ideas
« Reply #1 on: 03 April 2008, 08:26 »
I would suggest the first thing you do is remove the unit and check all your connections.
Then, using a multi-meter, check that you have the correct wires attached to the loom - (ignoring speakers) as a bare minimum you should have a (good) earth, a permanent live and a switched live.
If your connections are all good and you have the stereo connected as you should I would then ask a friend if you can swap stereo's with them for 5 minutes. If you can replicate the fault with your unit in their car, as well as use their stereo in your car with no problems it's pretty clear that your JVC unit is duff.
If this is the case when you return the unit make sure you let the vendor know exactly what you've done to confirm the fault is with the unit and not with the car and don't stand for any sh!t about them repairing it or getting it investigated. Make sure you demand a new unit.
The greatest leveller of them all - the Carousel
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #2 on: 03 April 2008, 10:24 »
Hi All
Humph
i dont want to insult your inteligence here but i run a jvc head unit, always have, if you dont physically switch them on with the on button they wont come on. however, they will allow ejecting and inserting cds which illuminates the backlight for about 4 seconds as you say.
 :smiley:
Offline Humph
« Reply #3 on: 03 April 2008, 21:30 »
Chris
Yep - pressed the power button several times, but with no effect.
S11EPS - Thanks - No multi-meter (I can see I am going to have to buy one and learn how to use it).  I have double and triple checked that all the connections in the block are okay and defo there are no loose wires.
I have thick red going to live, brown to earth and red/brown to permanent live - does that sound right.
The clock always rests itself to zero as soon as I take the key out of the ignition, if that gives any further clues. To me as a numpty, that means the permanent live is not effective or unit knackered.
Need to find somebody who I can swap stereos with as you suggest - then if still no joy I shall send back.
Humph
MK2 16V GTI
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« Reply #4 on: 04 April 2008, 00:57 »
This is yet another problem involving sufficient power supplies
From ur description, it is quite clear that you have just ONE live wire goin to the radio whereas you actually require TWO.
As another chappy mentioned, you require a permanent LIVE and a Switched Ignition LIVE.
However, not all older cars have an ignition LIVE n may only have the one. So therfore, being a JVC, on the radio loom that comes with it, just look at the Red n Yellow LIVE wires behind the radio, you will find they are attached via Bullet connections. One may be a double connection with one free bullet plug entry and the other just a single bullet connection.
Put whatever wire that is in the single bullet plug connection into the double one so in essence you are running both red and yellow wires off the same single wire coming from the car.If it powers up, then it has resolved your problem and diagnosed that you are initially a LIVE wire short. But from sum Mk2 golfs i have worked on, they DO have ignition LIVES so if you cannot locate one behind the radio connections or if there is already a ISO block connector ther, mite b worth checking your fuses to see which ones cater for radio function and find you may have a blown fuse that may solve your ignition LIVE problem and from then...activate and switch on with activation from your car ignition rather than independant even without ignition. But that is your own preference as to how you would prefer it. Its all simply done.
As for another members comment, JVC's do not have a history of having to be turned on everysingle time regardless as to if it was left in playing mode just before powering down your ignition. If that is the case, then u may possibly find that all your saved stations also reset and any sound settings you have set on the on board EQ. like bass and treble settings.
This is a simple case of your 2 LIVE wires (red & Yellow) are switched the wrong way round...so if you re-look at the JVC loom behind the radio, you may find that red is in yellow and yellow is in red....just switch them back to normal and that will then solve you problem too. If in the case the red is going to red and yellow to yellow on your JVC loom, then reverse it accordingly so it was as previously mentioned and then that may solve your issue!
If you're still unsure, then holler back:-)
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline S11EPS
« Reply #5 on: 04 April 2008, 08:59 »
If you loose the clock once the key comes out then you definitely don't have a permanant live connected correctly.
If you want to have a go yourself, try reading this post http://www.golfgtiforum.co.uk/index.php?topic=77360.msg625481#msg625481
It gives some basic instructions on how to use a multimeter to locate and identify the three power wires (earth, sw live, perm live).
Offline MooZ
« Reply #6 on: 20 April 2008, 20:26 »
I have just had the same problem with 2 DEfinitely good headunits I've tried to install, the one doesn't come on at all, the other you can hear the CD spinning or something happening for a few seconds then nothing, nothin on the display at all.
Lifes a beach!
so you may aswell die in a nice Bikini!
