Author Topic: Saggy doors...  (Read 3063 times)
Offline sarge
Saggy doors...
« on: 13 April 2004, 20:56 »
I have a mk2 driver which is - lets say - past its best. However full of the joys of spring I want to tackle the sagging doors. I seem to remember reading something in a mag years ago about mk2 doors and a fix for sagging door syndrome...any ideas?
Offline roar
Re:Saggy doors...
« Reply #1 on: 14 April 2004, 05:53 »
I never knew that mk2's were prone to this. :-X
Offline tallchap
Re:Saggy doors...
« Reply #2 on: 14 April 2004, 09:10 »
I used to have a mk1 cabrio and that suffered with saggy doors. A local bodyshop told me a trick that they use;
Open the door. Put a jack under the end of the door (use a block of wood between the jack and door so you don't damage it). Jack the jack until you start to see the car lift. Don't jack too much, take it slowly and release the pressure in the jack and check if the door now fits the whole properly. You may have to loosen the 'pin' which the door catches on (located in the back of the door shut) so that the door closes correctly into the shut. Repeat the jacking process until the door fits.
It worked for me, good luck!
Re:Saggy doors...
« Reply #3 on: 14 April 2004, 10:14 »
Another tip I've heard is to put a wheel bolt in the bottom of the hinge and slowly close the door.  If you do it too much put it in the top of the hinge and repeat :)
Blue MK2
Re:Saggy doors...
« Reply #4 on: 14 April 2004, 15:21 »
that trick never worked for my mk2 for some reason^^^
Re:Saggy doors...
« Reply #5 on: 15 April 2004, 09:45 »
I've never tried it either, I think the only other option is to replace the hinges and pins, a complete b!tch of a job I've heard :)
Offline Pike
Re:Saggy doors...
« Reply #6 on: 21 April 2004, 15:34 »
I repaired mine using the "jacking" method. I ground off the weld on the hinges and re-tacked them, been no probs since  ;D
Golf GTI Championship #4
2008 VW1 3rd
2009 VW1 3rd
Offline Johnny.A
Re:Saggy doors...
« Reply #7 on: 21 April 2004, 23:34 »
what wheels you got on your ride pike look well sweet!!  ;D
Offline Pike
Re:Saggy doors...
« Reply #8 on: 22 April 2004, 11:54 »
Cheers mate  ;D , they're 17" OZ Superleggera's
2008 VW1 3rd
2009 VW1 3rd
Fielder5757
Re:Saggy doors...
« Reply #9 on: 22 April 2004, 20:20 »
^^ NICE! i was gonna go for them but i went for Hydras instead, They where cheaper and almost as light ;)
