Author Topic: vagcom codes  (Read 6122 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
vagcom codes
« on: 28 March 2008, 14:41 »
how do i find out what the codes mean from the vag com.
Offline Rhyso
Offline (shakey)
Re: vagcom codes
« Reply #2 on: 28 March 2008, 15:11 »
what is this
16989 internal contr,module rom test error
16502 engine coolant temp,circ high input
00561 dont know what this one is.
Offline Rhyso
Re: vagcom codes
« Reply #3 on: 28 March 2008, 16:49 »
what is this
a stab at a guess is that your engine temperature sensor is on its way out.  do you experience poor performance etc?
Offline (shakey)
Re: vagcom codes
« Reply #4 on: 28 March 2008, 17:24 »
since having it remapped within the last 4days the performance has dropped dramaticaly is this what could be the lose of performance
Offline Rhyso
Re: vagcom codes
« Reply #5 on: 28 March 2008, 17:28 »
could well be as the map will be putting your engine components under greater pressure.  you might not have noticed anything until the remap.
who did the remap??
Offline (shakey)
Re: vagcom codes
« Reply #6 on: 28 March 2008, 17:42 »
remap was done by powertune in widnes cheshire
Offline Rhyso
Re: vagcom codes
« Reply #7 on: 28 March 2008, 17:54 »
what software did they use? Revo, Custom Code??
what sort of symptoms are you experiencing?
Offline (shakey)
Re: vagcom codes
« Reply #8 on: 28 March 2008, 18:19 »
been in touch with garage was not revo but he said it was his own software he downloaded onto the ecu, ive got loss of power from 3,000 revs right through all the gears
Offline Rhyso
Re: vagcom codes
« Reply #9 on: 28 March 2008, 18:22 »
hmmm could be boost leak  :undecided:  though that normally throws up an error code; could also be the MAF
could also be sh!te code!!
« Last Edit: 28 March 2008, 18:25 by Rhyso »
