Author Topic: OBD, VAGCOM, Fault Codes. What they mean and probable causes.  (Read 92801 times)
Offline richandhazel
Your one-stop place to look up the meaning of fault codes. I have more information available and will elaborate on any fault code at your request. Please ask in this thread.
I also have various related test procedures for sensors etc., so again, feel free to ask.
http://www.bentleypublishers.com/tech/vw/vw.dtc.table.htm
http://wiki.ross-tech.com/index.php/Category:Fault_Codes
http://www.airbagnews.com/PDF/Fehlercodes%20VAG%20english.pdf
« Last Edit: 29 July 2008, 23:15 by richw911 »
P0000 to P0250
« Reply #1 on: 26 February 2006, 23:40 »
16394
 P0010
 -A- Camshaft Pos. Actuator Circ. Bank 1 Malfunction
16395
 P0020
 -A- Camshaft Pos. Actuator Circ. Bank 2 Malfunction
16449
 P0065
 Air Assisted Injector Control Range/Performance
16450
 P0066
 Air Assisted Injector Control Low Input/Short to ground
16451
 P0067
 Air Assisted Injector Control Input/Short to B+
16485
 P0101
 Mass or Volume Air Flow Circ Range/Performance
16486
 P0102
 Mass or Volume Air Flow Circ Low Input
16487
 P0103
 Mass or Volume Air Flow Circ High Input
16489
 P0105
 Manifold Abs.Pressure or Bar.Pressure Voltage supply
16490
 P0106
 Manifold Abs.Pressure or Bar.Pressure Range/Performance
16491
 P0107
 Manifold Abs.Pressure or Bar.Pressure Low Input
16492
 P0108
 Manifold Abs.Pressure or Bar.Pressure High Input
16496
 P0112
 Intake Air Temp.Circ Low Input
16497
 P0113
 Intake Air Temp.Circ High Input
16500
 P0116
 Engine Coolant Temp.Circ Range/Performance
16501
 P0117
 Engine Coolant Temp.Circ Low Input
16502
 P0118
 Engine Coolant Temp.Circ High Input
16504
 P0120
 Throttle/Pedal Pos.Sensor A Circ Malfunction
16505
 P0121
 Throttle/Pedal Pos.Sensor A Circ Range/Performance
16506
 P0122
 Throttle/Pedal Pos.Sensor A Circ Low Input
16507
 P0123
 Throttle/Pedal Pos.Sensor A Circ High Input
16509
 P0125
 Insufficient Coolant Temp.for Closed Loop Fuel Control
16512
 P0128
 Coolant Thermostat/Valve Temperature below control range
16514
 P0130
 O2 Sensor Circ.,Bank1-Sensor1 Malfunction
16515
 P0131
 O2 Sensor Circ.,Bank1-Sensor1 Low Voltage
16516
 P0132
 O2 Sensor Circ.,Bank1-Sensor1 High Voltage
16517
 P0133
 O2 Sensor Circ.,Bank1-Sensor1 Slow Response
16518
 P0134
 O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
16519
 P0135
 O2 Sensor Heater Circ.,Bank1-Sensor1 Malfunction
16520
 P0136
 O2 Sensor Circ.,Bank1-Sensor2 Malfunction
16521
 P0137
 O2 Sensor Circ.,Bank1-Sensor2 Low Voltage
16522
 P0138
 O2 Sensor Circ.,Bank1-Sensor2 High Voltage
16523
 P0139
 O2 Sensor Circ.,Bank1-Sensor2 Slow Response
16524
 P0140
 O2 Sensor Circ.,Bank1-Sensor2 No Activity Detected
16525
 P0141
 O2 Sensor Heater Circ.,Bank1-Sensor2 Malfunction
16534
 P0150
 O2 Sensor Circ.,Bank2-Sensor1 Malfunction
16535
 P0151
 O2 Sensor Circ.,Bank2-Sensor1 Low Voltage
16536
 P0152
 O2 Sensor Circ.,Bank2-Sensor1 High Voltage
16537
 P0153
 O2 Sensor Circ.,Bank2-Sensor1 Slow Response
16538
 P0154
 O2 Sensor Circ.,Bank2-Sensor1 No Activity Detected
16539
 P0155
 O2 Sensor Heater Circ.,Bank2-Sensor1 Malfunction
16540
 P0156
 O2 Sensor Circ.,Bank2-Sensor2 Malfunction
16541
 P0157
 O2 Sensor Circ.,Bank2-Sensor2 Low Voltage
16542
 P0158
 O2 Sensor Circ.,Bank2-Sensor2 High Voltage
16543
 P0159
 O2 Sensor Circ.,Bank2-Sensor2 Slow Response
16544
 P0160
 O2 Sensor Circ.,Bank2-Sensor2 No Activity Detected
16545
 P0161
 O2 Sensor Heater Circ.,Bank2-Sensor2 Malfunction
16554
 P0170
 Fuel Trim,Bank1 Malfunction
16555
 P0171
 Fuel Trim,Bank1 System too Lean
16556
 P0172
 Fuel Trim,Bank1 System too Rich
16557
 P0173
 Fuel Trim,Bank2 Malfunction
16558
 P0174
 Fuel Trim,Bank2 System too Lean
16559
 P0175
 Fuel Trim,Bank2 System too Rich
16566
 P0182
 Fuel temperature sender-G81 Short to ground
16567
 P0183
 Fuel temperature sender-G81 Interruption/Short to B+
16581
 P0197
 Engine Oil Temperature Circuit Low Input
16582
 P0198
 Engine Oil Temperature Circuit High Input
16585
 P0201
 Cyl.1, Injector Circuit Fault in electrical circuit
16586
 P0202
 Cyl.2, Injector Circuit Fault in electrical circuit
16587
 P0203
 Cyl.3, Injector Circuit Fault in electrical circuit
16588
 P0204
 Cyl.4, Injector Circuit Fault in electrical circuit
16589
 P0205
 Cyl.5 Injector Circuit Fault in electrical circuit
16590
 P0206
 Cyl.6 Injector Circuit Fault in electrical circuit
16591
 P0207
 Cyl.7 Injector Circuit Fault in electrical circuit
16592
 P0208
 Cyl.8 Injector Circuit Fault in electrical circuit
16599
 P0215
 Engine Shut-Off Solenoid Malfunction
16600
 P0216
 Injector/Injection Timing Control Malfunction
16603
 P0219
 Engine Overspeed Condition
16605
 P0221
 Throttle Pos. Sensor -B- Circuit Range/Performance
16606
 P0222
 Throttle Pos. Sensor -B- Circuit Low Input
16607
 P0223
 Throttle Pos. Sensor -B- Circuit High Input
16609
 P0225
 Throttle Pos. Sensor -C- Circuit Voltage supply
16610
 P0226
 Throttle Pos. Sensor -C- Circuit Range/Performance
16611
 P0227
 Throttle Pos. Sensor -C- Circuit Low Input
16612
 P0228
 Throttle Pos. Sensor -C- Circuit Hight Input
16614
 P0230
 Fuel Pump Primary Circuit Fault in electrical circuit
16618
 P0234
 Turbocharger Overboost Condition Control limit exceeded
16619
 P0235
 Turbocharger Boost Sensor (A) Circ Control limit not reached
16620
 P0236
 Turbocharger Boost Sensor (A) Circ Range/Performance
16621
 P0237
 Turbocharger Boost Sensor (A) Circ Low Input
16622
 P0238
 Turbocharger Boost Sensor (A) Circ High Input
16627
 P0243
 Turbocharger Wastegate Solenoid (A) Open/Short Circuit to Ground
16629
 P0245
 Turbocharger Wastegate Solenoid (A) Low Input/Short to ground
16630
 P0246
 Turbocharger Wastegate Solenoid (A) High Input/Short to B
P0250 to P0500
« Reply #2 on: 26 February 2006, 23:42 »
16636
 P0252
 Injection Pump Metering Control (A) Range/Performance
16645
 P0261
 Cyl.1 Injector Circuit Low Input/Short to ground
16646
 P0262
 Cyl.1 Injector Circuit High Input/Short to B+
16648
 P0264
 Cyl.2 Injector Circuit Low Input/Short to ground
16649
 P0265
 Cyl.2 Injector Circuit High Input/Short to B+
16651
 P0267
 Cyl.3 Injector Circuit Low Input/Short to ground
16652
 P0268
 Cyl.3 Injector Circuit High Input/Short to B+
16654
 P0270
 Cyl.4 Injector Circuit Low Input/Short to ground
16655
 P0271
 Cyl.4 Injector Circuit High Input/Short to B+
16657
 P0273
 Cyl.5 Injector Circuit Low Input/Short to ground
16658
 P0274
 Cyl.5 Injector Circuit High Input/Short to B+
16660
 P0276
 Cyl.6 Injector Circuit Low Input/Short to ground
16661
 P0277
 Cyl.6 Injector Circuit High Input/Short to B+
16663
 P0279
 Cyl.7 Injector Circuit Low Input/Short to ground
16664
 P0280
 Cyl.7 Injector Circuit High Input/Short to B+
16666
 P0282
 Cyl.8 Injector Circuit Low Input/Short to ground
16667
 P0283
 Cyl.8 Injector Circuit High Input/Short to B+
16684
 P0300
 Random/Multiple Cylinder Misfire Detected
16685
 P0301
 Cyl.1 Misfire Detected
16686
 P0302
 Cyl.2 Misfire Detected
16687
 P0303
 Cyl.3 Misfire Detected
16688
 P0304
 Cyl.4 Misfire Detected
16689
 P0305
 Cyl.5 Misfire Detected
16690
 P0306
 Cyl.6 Misfire Detected
16691
 P0307
 Cyl.7 Misfire Detected
16692
 P0308
 Cyl.8 Misfire Detected
16697
 P0313
 Misfire Detected Low Fuel Level
16698
 P0314
 Single Cylinder Misfire
16705
 P0321
 Ign./Distributor Eng.Speed Inp.Circ Range/Performance
16706
 P0322
 Ign./Distributor Eng.Speed Inp.Circ No Signal
16709
 P0325
 Knock Sensor 1 Circuit Electrical Fault in Circuit
16710
 P0326
 Knock Sensor 1 Circuit Range/Performance
16711
 P0327
 Knock Sensor 1 Circ Low Input
16712
 P0328
 Knock Sensor 1 Circ High Input
16716
 P0332
 Knock Sensor 2 Circ Low Input
16717
 P0333
 Knock Sensor 2 Circ High Input
16719
 P0335
 Crankshaft Pos. Sensor (A) Circ Malfunction
16720
 P0336
 Crankshaft Pos. Sensor (A) Circ Range/Performance/Missing tooth
16721
 P0337
 Crankshaft Pos.Sensor (A) Circ Low Input
16724
 P0340
 Camshaft Pos. Sensor (A) Circ Incorrect allocation
16725
 P0341
 Camshaft Pos.Sensor Circ Range/Performance
16726
 P0342
 Camshaft Pos.Sensor Circ Low Input
16727
 P0343
 Camshaft Pos.Sensor Circ High Input
16735
 P0351
 Ignition Coil (A) Cyl.1 Prim./Sec. Circ Malfunction
16736
 P0352
 Ignition Coil (B) Cyl.2 Prim./Sec. Circ Malfunction
16737
 P0353
 Ignition Coil (C) Cyl.3 Prim./Sec. Circ Malfunction
16738
 P0354
 Ignition Coil (D) Cyl.4 Prim./Sec. Circ Malfunction
16739
 P0355
 Ignition Coil (E) Cyl.5 Prim./Sec. Circ Malfunction
16740
 P0356
 Ignition Coil (F) Cyl.6 Prim./Sec. Circ Malfunction
16741
 P0357
 Ignition Coil (G) Cyl.7 Prim./Sec. Circ Malfunction
16742
 P0358
 Ignition Coil (H) Cyl.8 Prim./Sec. Circ Malfunction
16764
 P0380
 Glow Plug/Heater Circuit (A) Electrical Fault in Circuit
16784
 P0400
 Exhaust Gas Recirc.Flow Malfunction
16785
 P0401
 Exhaust Gas Recirc.Flow Insufficient Detected
16786
 P0402
 Exhaust Gas Recirc.Flow Excessive Detected
16787
 P0403
 Exhaust Gas Recirc. Contr. Circ Malfunction
16788
 P0404
 Exhaust Gas Recirc. Contr. Circ Range/Performance
16789
 P0405
 Exhaust Gas Recirc. Sensor (A) Circ Low Input
16790
 P0406
 Exhaust Gas Recirc. Sensor (A) Circ High Input
16791
 P0407
 Exhaust Gas Recirc. Sensor (B) Circ Low Input
16792
 P0408
 Exhaust Gas Recirc. Sensor (B) Circ High Input
16794
 P0410
 Sec.Air Inj.Sys Malfunction
16795
 P0411
 Sec.Air Inj.Sys. Incorrect Flow Detected
16796
 P0412
 Sec.Air Inj.Sys.Switching Valve A Circ Malfunction
16802
 P0418
 Sec. Air Inj. Sys. Relay (A) Contr. Circ Malfunction
16804
 P0420
 Catalyst System,Bank1 Efficiency Below Threshold
16806
 P0422
 Main Catalyst,Bank1 Below Threshold
16811
 P0427
 Catalyst Temperature Sensor, Bank 1 Low Input/Short to ground
16812
 P0428
 Catalyst Temperature Sensor, Bank 1 High Input/Open/Short Circuit to B+
16816
 P0432
 Main Catalyst,Bank2 Efficiency Below Threshold
16820
 P0436
 Catalyst Temperature Sensor, Bank 2 Range/Performance
16821
 P0437
 Catalyst Temperature Sensor, Bank 2 Low Input/Short to ground
16822
 P0438
 Catalyst Temperature Sensor, Bank 2 High Input/Open/Short Circuit to B+
16824
 P0440
 EVAP Emission Contr.Sys. Malfunction
16825
 P0441
 EVAP Emission Contr.Sys.Incorrect Purge Flow
16826
 P0442
 EVAP Emission Contr.Sys.(Small Leak) Leak Detected
16827
 P0443
 EVAP Emiss. Contr. Sys. Purge Valve Circ Electrical Fault in Circuit
16836
 P0452
 EVAP Emission Contr.Sys.Press.Sensor Low Input
16837
 P0453
 EVAP Emission Contr.Sys.Press.Sensor High Input
16839
 P0455
 EVAP Emission Contr.Sys.(Gross Leak) Leak Detected
16845
 P0461
 Fuel Level Sensor Circ Range/Performance
16846
 P0462
 Fuel Level Sensor Circuit Low Input
16847
 P0463
 Fuel Level Sensor Circuit High Input
P0500 to P0750
« Reply #3 on: 26 February 2006, 23:43 »
16885
 P0501
 Vehicle Speed Sensor Range/Performance
16887
 P0503
 Vehicle Speed Sensor Intermittent/Erratic/High Input
16889
 P0505
 Idle Control System Malfunction
16890
 P0506
 Idle Control System RPM Lower than Expected
16891
 P0507
 Idle Control System Higher than Expected
16894
 P0510
 Closed Throttle Pos.Switch Malfunction
16915
 P0531
 A/C Refrigerant Pressure Sensor Circuit Range/Performance
16916
 P0532
 A/C Refrigerant Pressure Sensor Circuit Low Input
16917
 P0533
 A/C Refrigerant Pressure Sensor Circuit High Input
16935
 P0551
 Power Steering Pressure Sensor Circuit Range/Performance
16944
 P0560
 System Voltage Malfunction
16946
 P0562
 System Voltage Low Voltage
16947
 P0563
 System Voltage High Voltage
16952
 P0568
 Cruise Control Set Signal Incorrect Signal
16955
 P0571
 Cruise/Brake Switch (A) Circ Malfunction
16984
 P0600
 Serial Comm. Link (Data Bus) Message Missing
16985
 P0601
 Internal Contr.Module Memory Check Sum Error
16986
 P0602
 Control Module Programming Error/Malfunction
16987
 P0603
 Internal Contr.Module (KAM) Error
16988
 P0604
 Internal Contr.Module Random Access Memory (RAM) Error
16989
 P0605
 Internal Contr.Module ROM Test Error
16990
 P0606
 ECM/PCM Processor
17026
 P0642
 Knock Control Control Module Malfunction
17029
 P0645
 A/C Clutch Relay Control Circuit
17034
 P0650
 MIL Control Circuit Electrical Fault in Circuit
17038
 P0654
 Engine RPM Output Circuit Electrical Fault in Circuit
17040
 P0656
 Fuel Level Output Circuit Electrical Fault in Circuit
17084
 P0700
 Transm.Contr.System Malfunction
17086
 P0702
 Transm.Contr.System Electrical
17087
 P0703
 Torque Converter/Brake Switch B Circ Malfunction
17089
 P0705
 Transm.Range Sensor Circ.(PRNDL Inp.) Malfunction
17090
 P0706
 Transm.Range Sensor Circ Range/Performance
17091
 P0707
 Transm.Range Sensor Circ Low Input
17092
 P0708
 Transm.Range Sensor Circ High Input
17094
 P0710
 Transm.Fluid Temp.Sensor Circ. Malfunction
17095
 P0711
 Transm.Fluid Temp.Sensor Circ. Range/Performance
17096
 P0712
 Transm.Fluid Temp.Sensor Circ. Low Input
17097
 P0713
 Transm.Fluid Temp.Sensor Circ. High Input
17099
 P0715
 Input Turbine/Speed Sensor Circ. Malfunction
17100
 P0716
 Input Turbine/Speed Sensor Circ. Range/Performance
17101
 P0717
 Input Turbine/Speed Sensor Circ. No Signal
17105
 P0721
 Output Speed Sensor Circ Range/Performance
17106
 P0722
 Output Speed Sensor Circ No Signal
17109
 P0725
 Engine Speed Inp.Circ. Malfunction
17110
 P0726
 Engine Speed Inp.Circ. Range/Performance
17111
 P0727
 Engine Speed Inp.Circ. No Signal
17114
 P0730
 Gear Incorrect Ratio
17115
 P0731
 Gear 1 Incorrect Ratio
17116
 P0732
 Gear 2 Incorrect Ratio
17117
 P0733
 Gear 3 Incorrect Ratio
17118
 P0734
 Gear 4 Incorrect Ratio
17119
 P0735
 Gear 5 Incorrect Ratio
17124
 P0740
 Torque Converter Clutch Circ Malfunction
17125
 P0741
 Torque Converter Clutch Circ Performance or Stuck Off
17132
 P0748
 Pressure Contr.Solenoid Electrical
17134
 P0750
 Shift Solenoid A malfunction
P0751 to P1150
« Reply #4 on: 26 February 2006, 23:47 »
17135
 P0751
 Shift Solenoid A Performance or Stuck Off
17136
 P0752
 Shift Solenoid A Stuck On
17137
 P0753
 Shift Solenoid A Electrical
17140
 P0756
 Shift Solenoid B Performance or Stuck Off
17141
 P0757
 Shift Solenoid B Stuck On
17142
 P0758
 Shift Solenoid B Electrical
17145
 P0761
 Shift Solenoid C Performance or Stuck Off
17146
 P0762
 Shift Solenoid C Stuck On
17147
 P0763
 Shift Solenoid C Electrical
17152
 P0768
 Shift Solenoid D Electrical
17157
 P0773
 Shift Solenoid E Electrical
17174
 P0790
 Normal/Performance Switch Circ Malfunction
17509
 P1101
 O2 Sensor Circ.,Bank1-Sensor1Voltage too Low/Air Leak
17510
 P1102
 O2 Sensor Heating Circ.,Bank1-Sensor1 Short to B+
17511
 P1103
 O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
17512
 P1104
 Bank1-Sensor2 Voltage too Low/Air Leak
17513
 P1105
 O2 Sensor Heating Circ.,Bank1-Sensor2 Short to B+
17514
 P1106
 O2 Sensor Circ.,Bank2-Sensor1 Voltage too Low/Air Leak
17515
 P1107
 O2 Sensor Heating Circ.,Bank2-Sensor1 Short to B+
17516
 P1108
 O2 Sensor Heating Circ.,Bank2-Sensor1 Output too Low
17517
 P1109
 O2 Sensor Circ.,Bank2-Sensor2 Voltage too Low/Air Leak
17518
 P1110
 O2 Sensor Heating Circ.,Bank2-Sensor2 Short to B+
17519
 P1111
 O2 Control (Bank 1) System too lean
17520
 P1112
 O2 Control (Bank 1) System too rich
17521
 P1113
 Bank1-Sensor1 Internal Resistance too High
17522
 P1114
 Bank1-Sensor2 Internal Resistant too High
17523
 P1115
 O2 Sensor Heater Circ.,Bank1-Sensor1 Short to Ground
17524
 P1116
 O2 Sensor Heater Circ.,Bank1-Sensor1 Open
17525
 P1117
 O2 Sensor Heater Circ.,Bank1-Sensor2 Short to Ground
17526
 P1118
 O2 Sensor Heater Circ.,Bank1-Sensor2 Open
17527
 P1119
 O2 Sensor Heater Circ.,Bank2-Sensor1 Short to Ground
17528
 P1120
 O2 Sensor Heater Circ.,Bank2-Sensor1 Open
17529
 P1121
 O2 Sensor Heater Circ.,Bank2-Sensor2 Short to Ground
17530
 P1122
 O2 Sensor Heater Circ.,Bank2-Sensor2 Open
17531
 P1123
 Long Term Fuel Trim Add.Air.,Bank1 System too Rich
17532
 P1124
 Long Term Fuel Trim Add.Air.,Bank1 System too Lean
17533
 P1125
 Long Term Fuel Trim Add.Air.,Bank2 System too Rich
17534
 P1126
 Long Term Fuel Trim Add.Air.,Bank2 System too Lean
17535
 P1127
 Long Term Fuel Trim mult.,Bank1 System too Rich
17536
 P1128
 Long Term Fuel Trim mult.,Bank1 System too Lean
17537
 P1129
 Long Term Fuel Trim mult.,Bank2 System too Rich
17538
 P1130
 Long Term Fuel Trim mult.,Bank2 System too Lean
17539
 P1131
 Bank2-Sensor1 Internal Rsistance too High
17540
 P1132
 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Short to B+
17541
 P1133
 O2 Sensor Heating Circ.,Bank1+2-Sensor1 Electrical Malfunction
17542
 P1134
 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Short to B+
17543
 P1135
 O2 Sensor Heating Circ.,Bank1+2-Sensor2 Electrical Malfunction
17544
 P1136
 Long Term Fuel Trim Add.Fuel,Bank1 System too Lean
17545
 P1137
 Long Term Fuel Trim Add.Fuel,Bank1 System too Rich
17546
 P1138
 Long Term Fuel Trim Add.Fuel,Bank2 System too Lean
17547
 P1139
 Long Term Fuel Trim Add.Fuel,Bank2 System too Rich
17548
 P1140
 Bank2-Sensor2 Internal Resistance too High
17549
 P1141
 Load Calculation Cross Check Range/Performance
17550
 P1142
 Load Calculation Cross Check Lower Limit Exceeded
17551
 P1143
 Load Calculation Cross Check Upper Limit Exceeded
17552
 P1144
 Mass or Volume Air Flow Circ Open/Short to Ground
17553
 P1145
 Mass or Volume Air Flow Circ Short to B+
17554
 P1146
 Mass or Volume Air Flow Circ Supply Malfunction
17555
 P1147
 O2 Control (Bank 2) System too lean
17556
 P1148
 O2 Control (Bank 2) System too rich
17557
 P1149
 O2 Control (Bank 1) Out of range
17558
 P1150
 O2 Control (Bank 2) Out of range
P1151 to P1200
« Reply #5 on: 26 February 2006, 23:48 »
17559
 P1151
 Bank1, Long Term Fuel Trim, Range 1 Leanness Lower Limit Exceeded
17560
 P1152
 Bank1, Long Term Fuel Trim, Range 2 Leanness Lower Limit Exceeded
17562
 P1154
 Manifold Switch Over Malfunction
17563
 P1155
 Manifold Abs.Pressure Sensor Circ. Short to B+
17564
 P1156
 Manifold Abs.Pressure Sensor Circ. Open/Short to Ground
17565
 P1157
 Manifold Abs.Pressure Sensor Circ. Power Supply Malfunction
17566
 P1158
 Manifold Abs.Pressure Sensor Circ. Range/Performance
17568
 P1160
 Manifold Temp.Sensor Circ. Short to Ground
17569
 P1161
 Manifold Temp.Sensor Circ. Open/Short to B+
17570
 P1162
 Fuel Temp.Sensor Circ. Short to Ground
17571
 P1163
 Fuel Temp.Sensor Circ. Open/Short to B+
17572
 P1164
 Fuel Temperature Sensor Range/Performance/Incorrect Signal
17573
 P1165
 Bank1, Long Term Fuel Trim, Range 1 Rich Limit Exceeded
17574
 P1166
 Bank1, Long Term Fuel Trim, Range 2 Rich Limit Exceeded
17579
 P1171
 Throttle Actuation Potentiometer Sign.2 Range/Performance
17580
 P1172
 Throttle Actuation Potentiometer Sign.2 Signal too Low
17581
 P1173
 Throttle Actuation Potentiometer Sign.2 Signal too High
17582
 P1174
 Fuel Trim, Bank 1 Different injection times
17584
 P1176
 O2 Correction Behind Catalyst,B1 Limit Attained
17585
 P1177
 O2 Correction Behind Catalyst,B2 Limit Attained
17586
 P1178
 Linear 02 Sensor / Pump Current Open Circuit
17587
 P1179
 Linear 02 Sensor / Pump Current Short to ground
17588
 P1180
 Linear 02 Sensor / Pump Current Short to B+
17589
 P1181
 Linear 02 Sensor / Reference Voltage Open Circuit
17590
 P1182
 Linear 02 Sensor / Reference Voltage Short to ground
17591
 P1183
 Linear 02 Sensor / Reference Voltage Short to B+
17592
 P1184
 Linear 02 Sensor / Common Ground Wire Open Circuit
17593
 P1185
 Linear 02 Sensor / Common Ground Wire Short to ground
17594
 P1186
 Linear 02 Sensor / Common Ground Wire Short to B+
17595
 P1187
 Linear 02 Sensor / Compens. Resistor Open Circuit
17596
 P1188
 Linear 02 Sensor / Compens. Resistor Short to ground
17597
 P1189
 Linear 02 Sensor / Compens. Resistor Short to B+
17598
 P1190
 Linear 02 Sensor / Reference Voltage Incorrect Signal
17604
 P1196
 O2 Sensor Heater Circ.,Bank1-Sensor1 Electrical Malfunction
17605
 P1197
 O2 Sensor Heater Circ.,Bank2-Sensor1 Electrical Malfunction
17606
 P1198
 O2 Sensor Heater Circ.,Bank1-Sensor2 Electrical Malfunction
17607
 P1199
 O2 Sensor Heater Circ.,Bank2-Sensor2 Electrical Malfunction
P1201 to P1250
« Reply #6 on: 26 February 2006, 23:49 »
17609
 P1201
 Cyl.1-Fuel Inj.Circ. Electrical Malfunction
17610
 P1202
 Cyl.2-Fuel Inj.Circ. Electrical Malfunction
17611
 P1203
 Cyl.3-Fuel Inj.Circ. Electrical Malfunction
17612
 P1204
 Cyl.4-Fuel Inj.Circ. Electrical Malfunction
17613
 P1205
 Cyl.5-Fuel Inj.Circ. Electrical Malfunction
17614
 P1206
 Cyl.6-Fuel Inj.Circ. Electrical Malfunction
17615
 P1207
 Cyl.7-Fuel Inj.Circ. Electrical Malfunction
17616
 P1208
 Cyl.8-Fuel Inj.Circ. Electrical Malfunction
17617
 P1209
 Intake valves for cylinder shut-off Short circuit to ground
17618
 P1210
 Intake valves for cylinder shut-off Short to B+
17619
 P1211
 Intake valves for cylinder shut-off Open circuit
17621
 P1213
 Cyl.1-Fuel Inj.Circ. Short to B+
17622
 P1214
 Cyl.2-Fuel Inj.Circ. Short to B+
17623
 P1215
 Cyl.3-Fuel Inj.Circ. Short to B+
17624
 P1216
 Cyl.4-Fuel Inj.Circ. Short to B+
17625
 P1217
 Cyl.5-Fuel Inj.Circ. Short to B+
17626
 P1218
 Cyl.6-Fuel Inj.Circ. Short to B+
17627
 P1219
 Cyl.7-Fuel Inj.Circ. Short to B+
17628
 P1220
 Cyl.8-Fuel Inj.Circ. Short to B+
17629
 P1221
 Cylinder shut-off exhaust valves Short circuit to ground
17630
 P1222
 Cylinder shut-off exhaust valves Short to B+
17631
 P1223
 Cylinder shut-off exhaust valves Open circuit
17633
 P1225
 Cyl.1-Fuel Inj.Circ. Short to Ground
17634
 P1226
 Cyl.2-Fuel Inj.Circ. Short to Ground
17635
 P1227
 Cyl.3-Fuel Inj.Circ. Short to Ground
17636
 P1228
 Cyl.4-Fuel Inj.Circ. Short to Ground
17637
 P1229
 Cyl.5-Fuel Inj.Circ. Short to Ground
17638
 P1230
 Cyl.6-Fuel Inj.Circ. Short to Ground
17639
 P1231
 Cyl.7-Fuel Inj.Circ. Short to Ground
17640
 P1232
 Cyl.8-Fuel Inj.Circ. Short to Ground
17645
 P1237
 Cyl.1-Fuel Inj.Circ. Open Circ.
17646
 P1238
 Cyl.2-Fuel Inj.Circ. Open Circ.
17647
 P1239
 Cyl.3-Fuel Inj.Circ. Open Circ.
17648
 P1240
 Cyl.4-Fuel Inj.Circ. Open Circ.
17649
 P1241
 Cyl.5-Fuel Inj.Circ. Open Circ.
17650
 P1242
 Cyl.6-Fuel Inj.Circ. Open Circ.
17651
 P1243
 Cyl.7-Fuel Inj.Circ. Open Circ.
17652
 P1244
 Cyl.8-Fuel Inj.Circ. Open Circ.
17653
 P1245
 Needle Lift Sensor Circ. Short to Ground
17654
 P1246
 Needle Lift Sensor Circ. Range/Performance
17655
 P1247
 Needle Lift Sensor Circ. Open/Short to B+
17656
 P1248
 Injection Start Control Deviation
start of injection - control difference
Probable causes: fuel injection timing solenoid, injector needle lift sensor, fuel level low, pump timing
17657
 P1249
 Fuel consumption signal Electrical Fault in Circuit
17658
 P1250
 Fuel Level Too Low
« Last Edit: 05 February 2007, 15:41 by richandhazel »
P1251 to P1350
« Reply #7 on: 26 February 2006, 23:50 »
17659
 P1251
 Start of Injection Solenoid Circ Short to B+
17660
 P1252
 Start of Injection Solenoid Circ Open/Short to Ground
17661
 P1253
 Fuel consumption signal Short to ground
17662
 P1254
 Fuel consumption signal Short to B+
17663
 P1255
 Engine Coolant Temp.Circ Short to Ground
17664
 P1256
 Engine Coolant Temp.Circ Open/Short to B+
17665
 P1257
 Engine Coolant System Valve Open
17666
 P1258
 Engine Coolant System Valve Short to B+
17667
 P1259
 Engine Coolant System Valve Short to Ground
17688
 P1280
 Fuel Inj.Air Contr.Valve Circ. Flow too Low
17691
 P1283
 Fuel Inj.Air Contr.Valve Circ. Electrical Malfunction
17692
 P1284
 Fuel Inj.Air Contr.Valve Circ. Open
17693
 P1285
 Fuel Inj.Air Contr.Valve Circ. Short to Ground
17694
 P1286
 Fuel Inj.Air Contr.Valve Circ. Short to B+
17695
 P1287
 Turbocharger bypass valve open
17696
 P1288
 Turbocharger bypass valve short to B+
17697
 P1289
 Turbocharger bypass valve short to ground
17704
 P1296
 Cooling system malfunction
17705
 P1297
 Connection turbocharger - throttle valve pressure hose
17708
 P1300
 Misfire detected Reason: Fuel level too low
17721
 P1319
 Knock Sensor 1 Circ. Short to Ground
17728
 P1320
 Knock Sensor 2 Circ. Short to Ground
17729
 P1321
 Knock Sensor 3 Circ. Low Input
17730
 P1322
 Knock Sensor 3 Circ. High Input
17731
 P1323
 Knock Sensor 4 Circ. Low Input
17732
 P1324
 Knock Sensor 4 Circ. High Input
17733
 P1325
 Cyl.1-Knock Contr. Limit Attained
17734
 P1326
 Cyl.2-Knock Contr. Limit Attained
17735
 P1327
 Cyl.3-Knock Contr. Limit Attained
17736
 P1328
 Cyl.4-Knock Contr. Limit Attained
17737
 P1329
 Cyl.5-Knock Contr. Limit Attained
17738
 P1330
 Cyl.6-Knock Contr. Limit Attained
17739
 P1331
 Cyl.7-Knock Contr. Limit Attained
17740
 P1332
 Cyl.8-Knock Contr. Limit Attained
17743
 P1335
 Engine Torque Monitoring 2 Control Limint Exceeded
17744
 P1336
 Engine Torque Monitoring Adaptation at limit
17745
 P1337
 Camshaft Pos.Sensor,Bank1 Short to Ground
17746
 P1338
 Camshaft Pos.Sensor,Bank1 Open Circ./Short to B+
17747
 P1339
 Crankshaft Pos./Engine Speed Sensor Cross Connected
17748
 P1340
 Crankshaft-/Camshaft Pos.Sens.Signals Out of Sequence
Camshaft position (CMP) sensor 1/bank 1/crankshaft position (CKP) sensor - out of sequence
Probable cases: Valve timing, CKP/CMP sensor installation, CKP sensor rotor.
http://wiki.ross-tech.com/index.php/17748/P1340/004928
17749
 P1341
 Ignition Coil Power Output Stage 1 Short to Ground
17750
 P1342
 Ignition Coil Power Output Stage 1 Short to B+
17751
 P1343
 Ignition Coil Power Output Stage 2 Short to Ground
17752
 P1344
 Ignition Coil Power Output Stage 2 Short to B+
17753
 P1345
 Ignition Coil Power Output Stage 3 Short to Ground
17754
 P1346
 Ignition Coil Power Output Stage 3 Short to B+
17755
 P1347
 Bank2,Crankshaft-/Camshaft os.Sens.Sign. Out of Sequence
17756
 P1348
 Ignition Coil Power Output Stage 1 Open Circuit
17757
 P1349
 Ignition Coil Power Output Stage 2 Open Circuit
17758
 P1350
 Ignition Coil Power Output Stage 3 Open Circuit
« Last Edit: 05 February 2007, 15:19 by richandhazel »
P1351 to P1399
« Reply #8 on: 26 February 2006, 23:51 »
17762
 P1354
 Modulation Piston Displ.Sensor Circ. Malfunction
17763
 P1355
 Cyl. 1, ignition circuit Open Circuit
17764
 P1356
 Cyl. 1, ignition circuit Short to B+
17765
 P1357
 Cyl. 1, ignition circuit Short to ground
17766
 P1358
 Cyl. 2, ignition circuit Open Circuit
17767
 P1359
 Cyl. 2, ignition circuit Short Circuit to B+
17768
 P1360
 Cyl. 2, ignition circuit Short Circuit to Ground
17769
 P1361
 Cyl. 3, ignition circuit Open Circuit
17770
 P1362
 Cyl. 3, ignition circuit Short Circuit to B+
17771
 P1363
 Cyl. 3, ignition circuit Short Circuit to ground
17772
 P1364
 Cyl. 4 ignition circuit Open Circuit
17773
 P1365
 Cyl. 4 ignition circuit Short circuit to B+
17774
 P1366
 Cyl. 4 ignition circuit Short circuit to ground
17775
 P1367
 Cyl. 5, ignition circuit Open Circuit
17776
 P1368
 Cyl. 5, ignition circuit Short Circuit to B+
17777
 P1369
 Cyl. 5, ignition circuit short to ground
17778
 P1370
 Cyl. 6, ignition circuit Open Circuit
17779
 P1371
 Cyl. 6, ignition circuit Short Circuit to B+
17780
 P1372
 Cyl. 6, ignition circuit short to ground
17781
 P1373
 Cyl. 7, ignition circuit Open Circuit
17782
 P1374
 Cyl. 7, ignition circuit Short Circuit to B+
17783
 P1375
 Cyl. 7, ignition circuit short to ground
17784
 P1376
 Cyl. 8, ignition circuit Open Circuit
17785
 P1377
 Cyl. 8, ignition circuit Short Circuit to B+
17786
 P1378
 Cyl. 8, ignition circuit short to ground
17794
 P1386
 Internal Control Module Knock Control Circ.Error
17795
 P1387
 Internal Contr. Module altitude sensor error
17796
 P1388
 Internal Contr. Module drive by wire error
17799
 P1391
 Camshaft Pos.Sensor,Bank2 Short to Ground
17800
 P1392
 Camshaft Pos.Sensor,Bank2 Open Circ./Short to B+
17801
 P1393
 Ignition Coil Power Output Stage 1 Electrical Malfunction
17802
 P1394
 Ignition Coil Power Output Stage 2 Electrical Malfunction
17803
 P1395
 Ignition Coil Power Output Stage 3 Electrical Malfunction
17804
 P1396
 Engine Speed Sensor Missing Tooth
17805
 P1397
 Engine speed wheel Adaptation limit reached
17806
 P1398
 Engine RPM signal, TD Short to ground
17807
 P1399
 Engine RPM signal, TD Short Circuit to B+
P1400 to P1499
« Reply #9 on: 26 February 2006, 23:52 »
17808
 P1400
 EGR Valve Circ Electrical Malfunction
17809
 P1401
 EGR Valve Circ Short to Ground
17810
 P1402
 EGR Valve Circ Short to B+
17811
 P1403
 EGR Flow Deviation
17812
 P1404
 EGR Flow Basic Setting not carried out
17814
 P1406
 EGR Temp.Sensor Range/Performance
17815
 P1407
 EGR Temp.Sensor Signal too Low
17816
 P1408
 EGR Temp.Sensor Signal too High
17817
 P1409
 Tank Ventilation Valve Circ. Electrical Malfunction
17818
 P1410
 Tank Ventilation Valve Circ. Short to B+
17819
 P1411
 Sec.Air Inj.Sys.,Bank2 Flow too Flow
17820
 P1412
 EGR Different.Pressure Sensor Signal too Low
17821
 P1413
 EGR Different.Pressure Sensor Signal too High
17822
 P1414
 Sec.Air Inj.Sys.,Bank2 Leak Detected
17825
 P1417
 Fuel Level Sensor Circ Signal too Low
17826
 P1418
 Fuel Level Sensor Circ Signal too High
17828
 P1420
 Sec.Air Inj.Valve Circ Electrical Malfunction
17829
 P1421
 Sec.Air Inj.Valve Circ Short to Ground
17830
 P1422
 Sec.Air Inj.Sys.Contr.Valve Circ Short to B+
17831
 P1423
 Sec.Air Inj.Sys.,Bank1 Flow too Low
17832
 P1424
 Sec.Air Inj.Sys.,Bank1 Leak Detected
17833
 P1425
 Tank Vent.Valve Short to Ground
17834
 P1426
 Tank Vent.Valve Open
17840
 P1432
 Sec.Air Inj.Valve Open
17841
 P1433
 Sec.Air Inj.Sys.Pump Relay Circ. open
17842
 P1434
 Sec.Air Inj.Sys.Pump Relay Circ. Short to B+
17843
 P1435
 Sec.Air Inj.Sys.Pump Relay Circ. Short to ground
17844
 P1436
 Sec.Air Inj.Sys.Pump Relay Circ. Electrical Malfunction
17847
 P1439
 EGR Potentiometer Error in Basic Seting
17848
 P1440
 EGR Valve Power Stage Open
17849
 P1441
 EGR Valve Circ Open/Short to Ground
17850
 P1442
 EGR Valve Position Sensor Signal too high
17851
 P1443
 EGR Valve Position Sensor Signal too low
17852
 P1444
 EGR Valve Position Sensor range/performance
17853
 P1445
 Catalyst Temp.Sensor 2 Circ. Range/Performance
17854
 P1446
 Catalyst Temp.Circ Short to Ground
17855
 P1447
 Catalyst Temp.Circ Open/Short to B+
17856
 P1448
 Catalyst Temp.Sensor 2 Circ. Short to Ground
17857
 P1449
 Catalyst Temp.Sensor 2 Circ. Open/Short to B+
17858
 P1450
 Sec.Air Inj.Sys.Circ Short to B+
17859
 P1451
 Sec.Air Inj.Sys.Circ Short to Ground
17860
 P1452
 Sec.Air Inj.Sys. Open Circ.
17861
 P1453
 Exhaust gas temperature sensor 1 open/short to B+
17862
 P1454
 Exhaust gas temperature sensor short 1 to ground
17863
 P1455
 Exhaust gas temperature sensor 1 range/performance
17864
 P1456
 Exhaust gas temperature control bank 1 limit attained
17865
 P1457
 Exhaust gas temperature sensor 2 open/short to B+
17866
 P1458
 Exhaust gas temperature sensor 2 short to ground
17867
 P1459
 Exhaust gas temperature sensor 2 range/performance
17868
 P1460
 Exhaust gas temperature control bank 2 limit attained
17869
 P1461
 Exhaust gas temperature control bank 1 Range/Performance
17870
 P1462
 Exhaust gas temperature control bank 2 Range/Performance
17873
 P1465
 Additive Pump Short Circuit to B+
17874
 P1466
 Additive Pump Open/Short to Ground
17875
 P1467
 EVAP Canister Purge Solenoid Valve Short Circuit to B+
17876
 P1468
 EVAP Canister Purge Solenoid Valve Short Circuit to Ground
17877
 P1469
 EVAP Canister Purge Solenoid Valve Open Circuit
17878
 P1470
 EVAP Emission Contr.LDP Circ Electrical Malfunction
17879
 P1471
 EVAP Emission Contr.LDP Circ Short to B+
17880
 P1472
 EVAP Emission Contr.LDP Circ Short to Ground
17881
 P1473
 EVAP Emission Contr.LDP Circ Open Circ.
17882
 P1474
 EVAP Canister Purge Solenoid Valve electrical malfunction
17883
 P1475
 EVAP Emission Contr.LDP Circ Malfunction/Signal Circ.Open
17884
 P1476
 EVAP Emission Contr.LDP Circ Malfunction/Insufficient Vacuum
17885
 P1477
17886
 P1478
 EVAP Emission Contr.LDP Circ Clamped Tube Detected
