It took a long time to bleed the air out of mine.
Try filling it up put the cap on the expansion tank, then run the car, stop at 90 or 100 degrees, let it cool down then top it up.
Repeat 2 or 3 times until all bled.
Top rh corner of rad was the last place to be bled of air, which is where the thermo switch for the fan is, hence why my fan wouldn't cut in until the system was fully bled.
Paul
