Author Topic: Overheating!!!  (Read 3426 times)
Offline flatoot
Re: Overheating!!!
« Reply #20 on: 02 March 2009, 14:22 »
hi  im new to this site after recently purchasing a mk3 1.9d van  "aka   the can". I see in you post that is a while back that you have overheating probs and you symtoms are much the same as mine,   I dont think that the hose at the bottom of the rad should be cold?
did you get to the bottom of why this was?... :huh:
cheers Towers
Offline harlemex
Re: Overheating!!!
« Reply #21 on: 02 March 2009, 15:16 »
Take the thermostat out and test it in boiling water to see if it opens. This is the only way to know for sure if its faulty.
Offline flatoot
Re: Overheating!!!
« Reply #22 on: 02 March 2009, 16:02 »
ok m8 il give that a try and il buy another new one and test it aswell!
cheers :cool:
Offline 0191joe123
Re: Overheating!!!
« Reply #23 on: 02 March 2009, 16:11 »
just take the thermostat out mate and run the car with out it in ,the car doesnt need 1 in just means the car will take longer to warm up :wink:
Re: Overheating!!!
« Reply #24 on: 03 March 2009, 10:19 »
it does need a thermostat, you risk engine damage over time as car will never get fully up to temp. plus it'll use more fuel as it will continuously be stuck in cold running loop.
if you're going to all the effort to take the stat out, its madness not to just put a new one in  :rolleyes:
edit: oh and I've written up a coolant faq, its in the garage section. the bleeding method in there has never failed me ;)
Offline harlemex
Re: Overheating!!!
« Reply #25 on: 03 March 2009, 15:09 »
The one he is taking out is new. Testing it will confirm whether it works or not. If it works then youve saved a fiver! Also make sure you measure the water temp to determine that its opening at the right temp. I suspect the thermostat is fine though and you have head/ headgasket issue. :sick:
Offline jay6r
Re: Overheating!!!
« Reply #26 on: 16 April 2009, 19:00 »
Rmachines
any joy
 i found this topic on a search
 i am very curious to find out if you sorted it out as my newly acquired mk3 gti is doing exactly the same   its pissin me off big time.
any news would be great
jay
