Author Topic: Could door locks cause bad idle?!  (Read 1136 times)
Offline Godzilla
  • <<<VR6 MADNESS>>>
« on: 23 March 2008, 22:28 »
My central locking has packed up. It was not working that well when I bought the car. Now I still have my idle troubles...... due to the central locking system working of a vac' could that cause a leak and in turn cause bad running?!  I know it may sound mad but ive tried everything else with no joy.
Offline golf8v
Re: Could door locks cause bad idle?!
« Reply #1 on: 23 March 2008, 22:33 »
no mate the vacum is done by pump in boot nothing to do with engine..can you hear your central locking pump working?
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #2 on: 24 March 2008, 11:34 »
When I bought the car 2 weeks ago the central locking made a kind of whirr noise and all the locks worked via the central locking..... now there is no whirr noise and the central locking have stopped working.
Offline Jay
  • balding fat cvnt
« Reply #3 on: 24 March 2008, 11:39 »
The C/L will not effect the running of the car as it is independent from the rest of the systems (other than elecs). You may just need a new C/L pump to sort the C/L out, but first try cleaning the whole C/L system.
As for the idle troubles what have you tried?
Offline Conker
« Reply #4 on: 24 March 2008, 15:34 »
Have a look at this for a list of possibilities...
http://www.golfgtiforum.co.uk/index.php?topic=71501.msg569972#msg569972
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #5 on: 24 March 2008, 18:29 »
How do I clean the C/L system?
Idle cures so far are......
New HT leads
New plugs
New dizzy cap
New rotor arm
New vac pipes
Cleaned out all breathers and checked for cracks
Cleaned throttle body
New air filter
Cleaned ISV with carb cleaner
New Blue sensor
Timing and idle set
Still no joy with any of the above. It will be fine sometimes then others a real sod. It will idle between 750-1600 a few times (4-8 times) then settle at around 850.
Offline Conker
« Reply #6 on: 24 March 2008, 19:34 »
I think 850 is too low, try setting it to between 1000 and 1100. That might also cure the hunting idle as well.
Offline Godzilla
  • <<<VR6 MADNESS>>>
« Reply #7 on: 24 March 2008, 21:40 »
Thanks Conker, will try that tomorrow  :smiley:
Any ideas how to clean out  C/L system?
