Author Topic: amp wiring - earth cable  (Read 1964 times)
Offline Morgs
« on: 19 March 2008, 10:26 »
Can anyone tell me the best/easiest place to connect the earth cable in a mk4 golf.
thank you
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
Re: amp wiring - earth cable
« Reply #1 on: 19 March 2008, 11:05 »
on the left hand cubby hole in the boot.
open cubby hole door, stick head in, look up. you can share that one.
 :smiley:
Offline J5H VW
« Reply #2 on: 19 March 2008, 11:32 »
I used virtually the same spot in my mk3 golf - i used the bolt point that head the rear light cluster in place, just rubbed off some of the paint and attached the lead to the body using the bolt holding the lights in.
2001 VW 1.8t Golf GTi 5 Door (AUM). Xenons, Heated Black Recaro Leather, Front Arm Rest, Stubby Alloy Bee-sting, Climatronic, Heated Washers, Headlamp Jets, Touareg Torch...and a fire extinguisher should it all go wrong! - NOW SOLD
2005 BMW 330cd M Sport Convertible - Sparlking Graphite, Full Electric and Heated Red Leathers, TV, Nav, Bluetooth, Active Xenons, Wind Diffuser
« Reply #3 on: 19 March 2008, 13:34 »
anywhere you can make a good contact with the cars body is ok.
sometimes when you mention tapping your own people get a bit nervous.  :grin:
Offline Morgs
« Reply #4 on: 19 March 2008, 13:35 »
wheres the best way to run the power wire from the battery through the fire wall? there is an area where wires pass through but its really tight. is it best to drill your own hole?
thank you
« Reply #5 on: 19 March 2008, 13:49 »
there is a gromit just next to the pollen filter. (to the left of it if you standing infront of the car)
if you run from the battery up the plastic tunnel into where the pollen filter is that gromit will take you straight behind the glove box.
