Author Topic: facia's  (Read 3148 times)
Offline SteveS
  • GTI ED30
facia's
« on: 17 March 2008, 13:39 »
i need one, they are £10 on ebay :) VW want £18 which is fine...
one thing i want to know, the VW facias do they have like a metal cage on the back? or is it just all plastic.. im sure i have seen ones with a cage?
SteveS
ED30: Carbonio Intake & Filter | Blueflame TBE | Ebach Sportlines | Neuspeed Torque Arm Insert | Forge DV | REVO Stage2 [353BHP/360lb/ft]
Offline joesgti
Re: facia's
« Reply #1 on: 17 March 2008, 13:51 »
does the cage not come with the headunit? :huh:
GTI MK5
Not the only GTI...........but the best! ; )
Offline SteveS
  • GTI ED30
Re: facia's
« Reply #2 on: 17 March 2008, 13:57 »
yes, but im sure iv seen the actual facia with a cage round it..
SteveS
Offline Hurdy
Re: facia's
« Reply #3 on: 17 March 2008, 22:43 »
Some fascia's come with a side wall that can be up to a couple of inches deep. The steel cages come with the headunits. :nerd:
Seat Leon Cupra Black 290 DSG
Offline SteveS
  • GTI ED30
Re: facia's
« Reply #4 on: 18 March 2008, 09:28 »
hum should  buy from vw or save £7 on ebay then,... :rolleyes: lol
« Last Edit: 18 March 2008, 09:32 by SteveS »
SteveS
Offline Hurdy
Re: facia's
« Reply #5 on: 18 March 2008, 11:19 »
You need to see them in the flesh really. Some look pants and protrude too much from the dash, others are a different colour to the dash. It is worth looking around.
Offline SteveS
  • GTI ED30
Re: facia's
« Reply #6 on: 18 March 2008, 11:26 »
yeah thats my thoughts, but VW wont order one without my buying, and i cant check ebay ones... so i guess ill have to gamble... ill go with VWs as surly theirs will be perfect?
SteveS
Offline Hurdy
Re: facia's
« Reply #7 on: 18 March 2008, 11:32 »
The VW one is a decent match as far as fitment is concerned. The matt finish doesn't quite match (like mine), but I guess and exact match is near impossible. I did see one guys fascia who had the good thinking to get some anthracite leather and cover the fascia with it (to match his seats) and that looked lovely :wink: :cool:
Offline kenny.s
Re: facia's
« Reply #8 on: 18 March 2008, 11:47 »
I've got the VW one in mine, it had a divider in the middle so you could fit a single din headunit and a pocket but you just need to cut this bit out. You dont see where you've cut once the headunit is in, it's set back slightly from the front of the facia.
I think the colour match is about as good as you'll get, and the fit is pretty much spot on.
You can either screw the headunit directly to the facia and the fit it to the dash as per the std headunit or you can fit facia into the dash and then secure the steel cage that comes with your headunit to the fasia so you can remove your headunit as normal with the removal pins, so if you need to fit rca's etc and you dont need to take the dash apart.
Offline SteveS
  • GTI ED30
Re: facia's
« Reply #9 on: 18 March 2008, 12:01 »
im not sure that made too much sence? but i get bits of it.. lol... cool il just go to vw and order it then... bloody annoying i have to go in to order a cheap part!
SteveS
