Author Topic: headunit keeps resetting  (Read 3395 times)
Offline cm-gti
« on: 16 March 2008, 11:23 »
my headunit keeps resetting its self losing all radio and sound setting everytime i turn the ignition off its pi$$ing me right off i know its something to do with the power cable going to the headunit but i dont know what cable to look for or what to do once ive found it
plz someone help me out its driving me nuts
its a mk3 gti by the way
Offline richw911
Re: headunit keeps resetting
« Reply #1 on: 16 March 2008, 14:47 »
Right it depends on your head unit TBH but you should have a red live and a yellow live wire (please check colours before doing anything because thay do vary between head units!)
The red will be the main live and on the ignition so cuts off when you switch off.
 It sounds like Your yellow one which connects to the live also is on a switched live prob on the ingnition aswell,
 You need to put it onto a permanent live so it keeps your memory!
HTH
« Last Edit: 16 March 2008, 15:10 by richw911 »
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 16 March 2008, 14:55 »
and if swapping red and yellow dosen't sort it... repliy back as mk3's do have igntion switch problems!!
Offline cm-gti
« Reply #3 on: 16 March 2008, 19:06 »
thanks fellas will get on it tomorrow and let you know the outcome
Offline cm-gti
« Reply #4 on: 20 March 2008, 09:57 »
well i pulled the hu out its a sony by the way theres a red and a yellow but i was quickly stopped in my trackes all looked a bit complacated  :laugh: how do i put the yellow into a permanant live ? do i need to take all the ingnition out if so is it hard to do
Offline Andy!
  • VR6
« Reply #5 on: 20 March 2008, 09:59 »
Swap the red and yellow wires behind the headunit
Offline cm-gti
« Reply #6 on: 20 March 2008, 13:00 »
thanks taxiboy ill try that
Offline cm-gti
« Reply #7 on: 20 March 2008, 21:38 »
i had a nightmare trying to sort my problem out today as i was messing about with the live wire behind the headunit i touched the back of the headunit with the live it sparked when it touched so now my headunit dont work  :evil: the headunit does not turn on it wont play or the screen wont come on strangely all it will do is eject a cd i checked the fuse in the headunit it looks ok
so have i killed it or is there a fuse i could have blown that i can change
Offline Andy!
  • VR6
« Reply #8 on: 20 March 2008, 22:23 »
Have no fear,sounds like you blew the fuse on the car. Go to the fusebox(near your right knee) and on the detachable cover is a key that will tell you the fuse to examine.
Offline cm-gti
« Reply #9 on: 21 March 2008, 14:37 »
renewed fuse swapped live wires around everythings working spot on now
thanks for the help fellas
« Last Edit: 21 March 2008, 14:39 by cm-gti »
