Author Topic: DSG Kick-down override?  (Read 4407 times)
Offline Hurdy
Re: DSG Kick-down override?
« Reply #10 on: 16 March 2008, 00:04 »
how many miles on the clock when you decided to get it remapped???
Around 2,500 miles (4,000km).
Mine was too :cool:
Seat Leon Cupra Black 290 DSG
Offline Hurdy
« Reply #11 on: 16 March 2008, 00:05 »
Hi all,
Do any of you boffins know if it possible to override the kick-down when driving in manual mode? For example, I'm in manual mode and in 5th gear and I press the accelerator to the floor - the car will drop to 4th or maybe 3rd. Is there any way to avoid this?
The reason I ask is that I had my car Revo'd last week and the Revo agent was a bit unsure about dyno'ing a DSG as he's never dyno'd one before and said that the results would not be accurate as you need to be able to do a 100% throttle run in the gear closest to a 1:1 ratio (which he said would usually be 5th gear). He said the DSG kick-down at full throttle would mess up the results. How did you DSG owners who've been dyno'd get over this issue?
Last time I had mine rolling roaded they used 4th gear?!? :undecided:
Offline speedynz
« Reply #12 on: 16 March 2008, 23:51 »
Max Q,
If you quickly remove your DSG box and slot in a 'proper' 6spd manual then you should find that it will remain in the desired gear regardless of throttle position.
EDITION 30.
I couldn't eat a whole one.
Offline Max Q
« Reply #13 on: 17 March 2008, 00:17 »
Max Q,
Thanks, but I was hoping for an easier solution! :grin:
I read on a different forum that if you press and hold the '+' paddle and then give it full throttle it will prevent the box from downshifting. Must give this a try tomorrow and see if it works.
Mk7.5 R DSG Indium Grey 5Dr
Offline RedRobin
« Reply #14 on: 17 March 2008, 00:47 »
....Well that's totally logical if you think about it! By doing so you are continually sending the instruction. :cool:
Offline duffy78
« Reply #15 on: 17 March 2008, 15:59 »
dont you just put your foot down but not activate the kickdown switch at the full travel of the peddle?
if im in manual i can put my foot down in 5th at 40mph and it doesnt 'kick down' into a lower gear unless i put my foot to the floor and feel the switch being pressed.
Offline Max Q
« Reply #16 on: 17 March 2008, 22:19 »
So I tried this today and it does work. If you press and hold the '+' paddle it will initially shift up a gear but if you keep the paddle pressed you can give it full throttle up to and including the kick-down and it will not downshift. Give it a go.
Do I get a prize for answering my own question? :cool:
