Author Topic: F17BAD G3 GTI. S3 TURBO  (Read 1045250 times)
Offline Bellend
Re: F17BAD G3 GTI. S3 TURBO
« Reply #2070 on: 03 October 2011, 22:48 »
Normally air is for gays but IMO with the class of work put into this, it works. :cool:
Where all my moneys went.
Offline F17BAD
  • Golf MTM S3 GTI TURBO
« Reply #2071 on: 03 October 2011, 22:50 »
will this project ever end
shopping lists keep growing..
big brakes
big turbo
and now people are hitting me with Air ride
i need to go in a car with air ride before i can seriously consider it.. car is like a go kart at the mo and i like it
Not no ordinary GTI....
www.mixcloud.com/kells/
Offline Adam
« Reply #2072 on: 03 October 2011, 22:50 »
Two words come to mind again.....Air.......Ride.... :lipsrsealed:
THIS
Coilovers are for people who cant afford air ride  :smug:
Down Hill From Here.
Offline Bellend
« Reply #2073 on: 03 October 2011, 22:54 »
THIS
IMO for a fast road car, coilovers or even a shock/spring set up all the way. For some serious show car (which IMO this kinda is), air ride.
Say DMondays Seat had airride, well I've never met him but I'd run out the bush and slip it right inside him.
Whereas this just seems different.
Offline Lewy
« Reply #2074 on: 03 October 2011, 23:03 »
Wanna fcuk?
Offline Adam
« Reply #2075 on: 03 October 2011, 23:04 »
Wanna fcuk?
:laugh:
Offline SoundillusioN
« Reply #2076 on: 03 October 2011, 23:05 »
Wanna fcuk?
Mmmm, Air "Ride"  :grin:
Offline Bellend
« Reply #2077 on: 03 October 2011, 23:14 »
Wanna fcuk?
 :smug:
« Reply #2078 on: 03 October 2011, 23:52 »
Good luck with getting it sorted :afro:
Offline CCGTI
  • Fueled Society
« Reply #2079 on: 04 October 2011, 09:02 »
Air ride is sh!t brad, been in a few cars now with it, if you are going to be a show car whore and leave it in a garage do it, if you want to drive the car proper and corner well dont touch it,
Air ride is made for wagons, buses and disabled people carrierso
I know one lad who had it and drove his car as a daily kept splitting the bags and had to get recovered
I would go for this, better road handling
KW HLS
 HLS is available in two different versions: HLS 2 which is fitted to the front axle and HLS 4 which can be attached to the front and rear axle and allows lifting the entire vehicle. The hydraulic cylinder unit is located on the coilover body between spring perch and spring. Depending on the car type and model, KW HLS is either available as a vehicle-specific solution or as a conversion kit for KW or OEM coilover kits. Allows cars with low ground clearance to clear obstacles more easily
Available as complete kit including KW coilover kit or as conversion kit
Fast lifting - maximum lift occurs within 4 to 5 seconds when using HLS 2
