Author Topic: Removel of the 16v inlet Manifold  (Read 918 times)
Offline STEALTH K3
« on: 09 March 2008, 20:25 »
Toying with the idea of doing this as I have a polished one and it is in need of a quick rub down is this a job for a novice
Offline Conker
Re: Removel of the 16v inlet Manifold
« Reply #1 on: 13 March 2008, 13:21 »
Are you asking how to do it??
Offline kerrly
« Reply #2 on: 03 April 2008, 14:54 »
i think its fair to assume he wants to know how to remove the inlet if he has a polished one?
1) disconnect the plastic air inlet pipe from air box to the throttle body - 1 jubilee clip
2) remove rubber vacuum lines - depending if you have a mk2 or mk3 there will be either 1 or 2 at the back of the manifold
3) undo 3or4 13mm bolts on back of manifold which attach it to bracket which connects to the block
4) Prise the injectors out- they will be difficult to pull out- dont be too brutal with them as you can bend them.
5) undo 8x 6mm allenkey bolts which attach manifold to front of the block - note use plenty of WB40 or similar and be sure to hammer the allen key in to make sure its sat properly before attempting to undo- you really DO NOT want to round these!
alternatively, you can get away with polishing the manifold already in use... pull the HT leads out , put a towel on top of the rocker cover to catch the dust etc and you should be alright.
Dave
« Last Edit: 03 April 2008, 14:57 by kerrly »
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 03 April 2008, 20:47 »
its worth changing the injector seals too if they are not a tight fit, 60p ea from gscp's
Offline kerrly
« Reply #4 on: 04 April 2008, 16:23 »
Very good shout!!!!! + upper and lower inlet manifold gaskets to, available from GSF.. should have mentioned that in my OP.
