Author Topic: EXHAUST ISSUES!!  (Read 1633 times)
Offline vdub virgin
  • If it aint broke....dont fix it!!
EXHAUST ISSUES!!
« on: 08 March 2008, 20:32 »
does any1 else hav problems with exhausts?
gt a standard exhaust on it n replaced the middle box 2 weeks ago n noticed there wasnt much room or much give in the exhaust around middle n back box,
but was fine............4 a week!
set off 1 day and middle box was knocking on floor pan n by end of day both the new clamps had loosened n it was blowing like f*ck! :angry:
had it tightened n re-aligned on weds n was fine until i booted it in second 2day n then i heard the dreaded knocking noise again!by the time i got home it was blowin!
this common problem with these exhausts?
gonna spot weld the clamps to stop em cummin lose nut surely u shouldnt hav to go to these lengths?
 :cry:
Offline Kenny_1.6
  • it will be a GTi... some day... lol
Re: EXHAUST ISSUES!!
« Reply #1 on: 08 March 2008, 20:46 »
i had the same problem... bit of exhaust gum sorted it out  :wink:
Men have two emotions: Hungry and Horny. If you see one without an erection, make him a sandwich. :D
Offline Stu G
« Reply #2 on: 08 March 2008, 20:55 »
where did ya have the exhasut fitted mate? being an exhaust fitter its rare that clamps come loose. one thing could be just a sh!t fitting exhaust and be slightly too big for the pipe so wont grip.
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 09 March 2008, 11:22 »
this problem can be caused by the small section after the cat,,,its just an extra piece of foot long pipe and if thats not fitted well the whole exhaust will be off! causing problems like yours!
I would check thats fitted fine first and adjust the exhaust there for better fit
Offline vdub virgin
« Reply #4 on: 09 March 2008, 16:37 »
il hav another go at it 2moro,bloody golfs!
gonna put lockin nuts on the clamps,thatl cap em! little buggers!lol! :smiley:
Offline herbster
« Reply #5 on: 09 March 2008, 16:43 »
You need to use aero lock nuts not the normal nyloc ones as they will melt! There are lots of types on the market, have a good look around, try - www.bapp.co.uk
FAB is my life and the CABRIO's the wifes!!!!
Offline vdub virgin
« Reply #6 on: 09 March 2008, 16:44 »
when u re-do it everythings spot on n no knockin etc,bt as soon as you boot it its pulled outta place again!
could there be too much wear in the engine mounts so when you boot it the engines pulling on the exhaust?
Offline vdub virgin
« Reply #7 on: 09 March 2008, 16:45 »
cheers dude! :smiley:
Offline herbster
« Reply #8 on: 09 March 2008, 16:50 »
Web sites off line at the mo for whatever reason, look some indusrial fittings places up in the thom local, bet theres one just round your corner!!!
Offline Stu G
« Reply #9 on: 09 March 2008, 17:28 »
stop being a gibbon and get a stainless system slapped on :D
