Author Topic: Removing PAS  (Read 1082 times)
Offline Stu.750
  • MMMMMMM Rust my favourite
Removing PAS
« on: 03 March 2008, 16:37 »
Is it Difficult or just a matter of fitting a non PAS rack and removing all the gubbins associated with the system ?
Offline Jay
  • balding fat cvnt
Re: Removing PAS
« Reply #1 on: 03 March 2008, 21:33 »
Should be that 'simple'   :rolleyes:
PAS is sooooo 90's  :laugh:
Offline bomp
Re: Removing PAS
« Reply #2 on: 04 March 2008, 00:28 »
It's aparantly a bit fidly with the PAS, (removing or putting one in anyways) , remove exhaust down pipe/manifold for ease of access and lower the rear of the subframe a bit by the rear wishbone bushes. Universal joint is a slightly different length and the rubber shroud that covers it is a different shape. I think the rack to sub frame rubbers are slightly different too.
Life is like a skid mark on a toilet bowl.  Sooner or later someone\\\'s going to pi$$ you off.
Offline Stu.750
Re: Removing PAS
« Reply #3 on: 04 March 2008, 00:43 »
Well the engine and frame should be coming out anyways , its being used as a race car so its one less thing to go wrong and you get a bit more feel without it
Offline Diamond Hell
  • Opinions я Us
Re: Removing PAS
« Reply #4 on: 04 March 2008, 08:23 »
Quote
If that's the case then you should leave the PAS in - it's a quicker rack, which means you'll be doing less arm twirling to keep up with the crowd.
Offline bomp
Re: Removing PAS
« Reply #5 on: 04 March 2008, 12:12 »
Oh right, yeah that'll take a few pounds in weight off your car then. Sell the whole gubbins on with the double pulley and belt tensioner to get some money back.
Is there much of a difference in the turning ratio between PAS and non PAS?
Offline Stu.750
Re: Removing PAS
« Reply #6 on: 04 March 2008, 13:48 »
Quote
 Do you know what the rack ratio lock to lock differance is ?
 Exactly what i was thinking , the car ive got has electric everythin , windows and mirrors so im gettin rid of those too
