Author Topic: Help...Spraying Wheels  (Read 1168 times)
Offline admc6
« on: 03 March 2008, 15:06 »
I have come round to spraying the centre of my split rims and was wanting to know the best way to go about it.
Can i just spray the parts that i have fixed or do i need to spray all of the wheel?
Do i have to take off all the old paint?
Will the new primer and paint stick to the old lacquered surface or should i just rough it up a bit first?
Offline remapped
  • If you are going through Hell, keep going
Re: Help...Spraying Wheels
« Reply #1 on: 03 March 2008, 18:31 »
there a link on here that will help !! will try to find it
OEM(ish) G3GTi 8v5dr
Offline BobbyT
« Reply #2 on: 03 March 2008, 22:10 »
if the paint is ok, just rub it down and spray the wheel, i would do the whole thing! just done my wheels today, well two of them  :wink:
oh and loads of laquer on top
Offline Mikester
  • Civic Type R
« Reply #3 on: 04 March 2008, 09:36 »
*rub down the whole wheel
*prime the whole wheel
*rub it down
*prime again
*rub it down slightly
*spray colour
*rub it down
*spray colour
*rub it down a bit
*spray colour
*leave to dry for a few days in warm with no dirt or breeze
*laquer and dry
*lauer and dry
*laquer and dry.
Dont part spray them, or spray over the old laquer, unless you want patchy wheels with paint peeling off  :sick:
Offline admc6
« Reply #4 on: 04 March 2008, 10:37 »
I will get a picture on for you later.
So would i have to take off all the laquered paint on the face bit of the wheel?
I read somewhere it would come off fairly easy if you put it completely in nitromors for the 20 or so mins then poor boiling water on top to neutralize it and put a lid on as it helps with the paint removal. Then all you have to do is give it a scrape.
If i did this, would you rub the top down first to break trough the laquer that is already there?
Offline Mikester
  • Civic Type R
« Reply #5 on: 04 March 2008, 10:54 »
Thats correct, it will take of the laquer, then you need to sand it down, not scrape!!! sand it down till you at the metal, and its smooth, then fill any kurbing etc. Then use METAL primer, abd build up the layers and rubbin down as i said.  :cool:
Offline admc6
« Reply #6 on: 04 March 2008, 12:38 »
Great i will do that then. No need to worry about kurbing on them, just a little corrosion on the paint, as its the middle of the split rims. Eill sort a picture out for you when i get home from work
Offline Mikester
  • Civic Type R
« Reply #7 on: 04 March 2008, 12:41 »
Cool beans mate, any problems, just ask, not a problem  :cool:
