Author Topic: rear wheel bearings  (Read 2009 times)
Offline jammac
rear wheel bearings
« on: 29 February 2008, 15:01 »
on my MOT i got an advisory for "slight play in both rear wheel bearings"
the guy said they were easy to adjust........... i assume i just need to remove the split pin and tighten up the hub nut then put a new split pin through? please correct me if im wrong
my question is....... does anyone know the correct torque figure for the rear hub nut?
ive left my haynes manual at work and wanted to do it over the weekend.
cheers all
ITS A TRAP!
Offline jammac
Re: rear wheel bearings
« Reply #1 on: 29 February 2008, 15:01 »
opps i forgot its a mk2 91 8v
if that makes any differance?  :rolleyes:
ITS A TRAP!
Offline JimR
« Reply #2 on: 29 February 2008, 15:40 »
I'm not sure there is a torque setting for them, i did mine recently and couldn't find anything. I just did mine until the wheel became stiff to turn then backed it off slightly.
Mk2 GTi.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 29 February 2008, 15:43 »
same as jim i had slight play, did them up tight and then back a touch this usually sorts them out.
Offline Jay
  • balding fat cvnt
« Reply #4 on: 01 March 2008, 21:02 »
Make sure they're not too tight, that's how I fecked mine.
Offline jammac
« Reply #5 on: 02 March 2008, 09:59 »
ive not done it yet........ but ill think ill just do it up tight then back off abit like y'all say but sounds abit sh!te to me. there must be a correct figure that you can tighten it to then forget about em.
 :cool:
ITS A TRAP!
Offline dirk
« Reply #6 on: 02 March 2008, 18:03 »
No need to 'tighten' them, this will ruin them, all thats is needed is for the nut to be nipped up, no more is neccessary. I know it feels a bit wrong but if anything, a 'nip' is all thats needed. Just make sure its all nicely greased up, all the rollers within the inner and outer race are full of grease and the jobs a good'un!
Offline jammac
« Reply #7 on: 03 March 2008, 16:17 »
what kind of grease should be used for this? i take it copper grease is a no good.
ITS A TRAP!
Offline dirk
« Reply #8 on: 03 March 2008, 19:23 »
just high temp grease will do the job!u can get it from any motorfactors.
Offline JC
  • Back in the North.
« Reply #9 on: 03 March 2008, 19:29 »
which airline do you spanner for  :shocked: - just so I know like  :laugh:
