Author Topic: best door speaker upgrade for mk4  (Read 4308 times)
Offline Heyho
Re: best door speaker upgrade for mk4
« Reply #10 on: 01 March 2008, 19:53 »
It probably sounds farty because your headunit is running out of puff.
With £70 to play with, I'd invest in a good 2-channel amp, and use it to power the front speakers.  90% of what people hear as distortion is produced by the source, and not the speakers - speakers distorting make a completely different sound when they hit their mechanical limit.
Offline Chris 'N' Jen
  • MK4 2.0 GTi 8v in black (the best colour)
« Reply #11 on: 02 March 2008, 22:08 »
Just drill the rivets out then use a nut n bolt to fix your new pod in place.
No need to remove metal panel as you fit pod into pannel then speaker into pod.
 :smiley:
Offline gtisteve
« Reply #12 on: 04 March 2008, 17:41 »
Go for components if you can afford, they sound sweet, and amp if possible. Don't rule out second hand if the budget is tight, I got a set of Kenwood componets unused and still in the box with a kenwood amp for £50. Need to check for sale sections of forums :wink:
