Author Topic: LL's Mk3 1.8t Cab  (Read 921929 times)
Re: LL's Mk3 1.8t [projectninetynine]
« Reply #2170 on: 17 February 2011, 12:24 »
LUK, could probs get it cheaper locally. Might be able to get a Sachs with a bit of discount too. But my current one is Sachs and if it is the clutch that has gone, I'd probably try a different one.
Very stange for a Sachs to have such a short life, both Sachs and LUK are really good choices.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2171 on: 17 February 2011, 13:18 »
Yer, I'm going to try adjusting the cable in a bit.
I went to St Austell (2 hour round trip) with 4 people including me, and I noticed it had got a lot worse by the time I got back. Seems odd that it went very quick from slipping a little in 5th to slipping in 3rd!
Its only when I come on boost too.
Offline Len
« Reply #2172 on: 17 February 2011, 13:20 »
Those SACHS clutches not as good as they supposed to be then! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
« Reply #2173 on: 17 February 2011, 13:34 »
Yep they are excellent and I am not the only member to say so, any clutch can slip if given enough abuse or suffer from oil leaking onto it.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2174 on: 17 February 2011, 13:42 »
There is no smell either.
Offline GrandMstRamRod
« Reply #2175 on: 17 February 2011, 22:49 »
abuse then!
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2176 on: 17 February 2011, 23:14 »
Well drives fine as long as I stay off boost, went up a hill in 4th no worries.
Offline Diamond Hell
  • Opinions я Us
« Reply #2177 on: 18 February 2011, 13:24 »
Do you ride your clutch, boi?  Could result in accelerated wear on it.
Have you checked underneath for any oil?
TBH I wouldn't be surprised if a lilly-livered little scrote like you rode your clutch.
You're the type for it.  :grin:
Offline Len
« Reply #2178 on: 18 February 2011, 13:27 »
I used to ride clutches........
I prefer women these days!
www.sas.org.uk
www.the-ace.org.uk
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2179 on: 18 February 2011, 13:34 »
No I do not ride my clutch, you geriatric f**k. Even so, can't see it wearing out that quick!
Can't see any oil underneath either.
