Author Topic: LL's Mk3 1.8t Cab  (Read 923046 times)
Offline SoundillusioN
Re: LL's Mk3 1.8t [projectninetynine]
« Reply #2160 on: 16 February 2011, 23:29 »
hmm is that how you do it..
usually its done with suction mounts on the car with a low exposure and a slow shutter speed.
This one looks like it could be shopped as it has no driver unless he was hiding.  :grin:
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2161 on: 16 February 2011, 23:33 »
Thanks guys. Will be doing it again when its clean!
Yeah that 2nd pic - we pushed it :D
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2162 on: 17 February 2011, 10:08 »
New clutch? F**k.
Think its time after 10,000ish miles. Was slipping a little in 5th before, now its slipping in 3rd and 4th. Thought it might have been the DV at first, as the boost fluctuates quite a bit. Plus at the rolling road day I asked JKM if they noticed the clutch slipping and they said no, just the boost fluctuating....
I'm also wondering if it could be something else. Is there a seal in the box or something that could be leaking? Or maybe the cable for the clutch pedal needs adjusting?
Will be grabbing a new 007p anyway cause I need one and then if that doesn't make a difference I guess I'll get the box off and have a look. If its new clutch time, then so be it! Be an excuse to fit my TDI box and Mk4 shift setup.
« Reply #2163 on: 17 February 2011, 10:34 »
10k is not good for a clutch, you might have oil leaking onto it from the crankshaft oil seal.
« Reply #2164 on: 17 February 2011, 10:46 »
Booo what a pain in the ass, but then if you have new gear you want to put in and you're in a position to do it then now's a good time I suppose, and if Wayne's point is the issue at least you will see then.
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2165 on: 17 February 2011, 11:22 »
Ah OK, I thought there was a seal that can leak, remember reading it somewhere.
I know its got a fair bit of torque/power or whatever but not THAT much to kill a clutch that quick :D Plus most of that 10k is easy driving.
Yeah that's the plan Shaun, check it out. If it happens to be the clutch, then so be it. They are easy to get ahold of on the day or next day, so no worries there.
« Reply #2166 on: 17 February 2011, 11:28 »
Yeah but how much for a new kit?
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2167 on: 17 February 2011, 12:13 »
£120.
« Reply #2168 on: 17 February 2011, 12:18 »
Offline LazyLunatic
  • MK3 20VT Project
« Reply #2169 on: 17 February 2011, 12:22 »
LUK, could probs get it cheaper locally. Might be able to get a Sachs with a bit of discount too. But my current one is Sachs and if it is the clutch that has gone, I'd probably try a different one.
