Author Topic: Clutch and sunroof  (Read 1453 times)
Offline Peterdevo
  • 07917 447877
Clutch and sunroof
« on: 27 February 2008, 17:30 »
Recently I had the citch cable changed as the pedal was stiff and noisy.
This has improved the situation considerably but today I noticed that there is a slight noise on take up.
Is this anything to worry about? I really hope that it is not the sign of the clutch plate going somewhere in the next few months. There is plenty of bite but it is probably the original clutch at 105000m but used for mostly motorway miles.
The sunroof is prone to rattle. Does anyone else have this problem and any idea how to fix it>
Peter
Offline saul79
Re: Clutch and sunroof
« Reply #1 on: 27 February 2008, 22:32 »
release bearing /thrust bearing noisey?
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Peterdevo
  • 07917 447877
« Reply #2 on: 28 February 2008, 19:39 »
Thanks for that. Although I always thought that if the thrust bearing was noisy it would do it when the clutch pedal is depressed. I wonder if it is a big job if it is the release bearing?
Offline saul79
« Reply #3 on: 28 February 2008, 20:18 »
there both the same mate -just everybody uses different names for them .it can make a noise when it isnt depressed .
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 28 February 2008, 20:35 »
5 minute job to fit as its no where near the clutch plate/cover... its hiding under the green cover on the box side!
Offline saul79
« Reply #5 on: 28 February 2008, 20:40 »
yep remove the green plate unclip the fork get a magnet and remove the bearing
Offline saul79
« Reply #6 on: 28 February 2008, 20:40 »
i always swap the rod around what runs through the center as it gets rounded
  • Back in a Mk3...
« Reply #7 on: 28 February 2008, 20:42 »
and they snap/crack.... mine did and it took weeks of searching as it was hidden!!
Offline saul79
« Reply #8 on: 28 February 2008, 20:48 »
haha the fork snapped on mine  :angry:
Offline Peterdevo
  • 07917 447877
« Reply #9 on: 29 February 2008, 17:33 »
Thanks for your invaluable help.
Great news today. My Golf GTI passed the MOT test and the examiner says he has not seen many cars in such good condition and the exhaust emissions were only 0.025 as against 0.2 allowable. Result
