Author Topic: Wing mounted ariel removal ???  (Read 4400 times)
kells
« on: 27 February 2008, 17:02 »
Yo
wanting to whip out the ariel as some kind person has already removed most of it :angry:
plan is to remove it and put a gromet i have from the dealer in as a temp fix till i get the late type wings, not putting a B sting on either as i want the NO ariel look, gonna use a window mounted affair
question is how the hell do u get the old ariel out of the wing, i have got it released but only so far and i cannot get it to move anymore, it does however spin around :rolleyes:
anyone ??
Ta
Offline boneybradley
  • Back in a Mk3...
Re: Wing mounted ariel removal ???
« Reply #1 on: 27 February 2008, 17:13 »
its bolted to the inner wing and requires removal of the plastic arch for access...
kells
« Reply #2 on: 27 February 2008, 17:44 »
pain in the anus of a job is it??
  • Back in a Mk3...
« Reply #3 on: 27 February 2008, 18:57 »
Not a pain really.....but it's will take time to get the arch liner off...I managed to remove one end and slide my hand in to yank the aerial off
kells
« Reply #4 on: 27 February 2008, 19:07 »
thats what ium thinking, if i just get enough clearence to get my hand in, how is it attached inside the wing?  is it a bolt or what??
and it appears it needs to come outwards from the outside is that thw case??
  • Back in a Mk3...
« Reply #5 on: 27 February 2008, 19:43 »
mine came downwords and its attached using a metal strip..thats bolted to the inner wing and i just snipped in the middle mine with pliers to remove
kells
« Reply #6 on: 27 February 2008, 19:59 »
will look into it then
do u have one of these in clear not green btw?? random i know
  • Back in a Mk3...
« Reply #7 on: 27 February 2008, 20:01 »
only green worst luck...
kells
« Reply #8 on: 27 February 2008, 20:05 »
bummer :sad:
Offline Guy
« Reply #9 on: 27 February 2008, 21:43 »
wtf?  :huh:
