Author Topic: Vr6 timing  (Read 1293 times)
Offline pink mk1
Vr6 timing
« on: 27 February 2008, 11:51 »
hi all need some help on tweaking
my voora's timeing
i know its out at the moment
but needs help and want to get more out of it
performance wise
PLS HELP
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: Vr6 timing
« Reply #1 on: 27 February 2008, 12:45 »
Use a timing strobe to set it up correctly, you can advance the timing slightly, will cause the engine to "pink" (knock)  so you would need to reduce intake temp and use higer grade fuel,  now if you run on optimax all the time and have a very good cold air feed you can usualy get away with advancing the timing a fair amount to get more power and a better burn,  Doesnt make a huge amount of diffrence and you must be carefull not to advance to much,  golder grade sparkplugs are a good idea aswell but not nessasry unless your running a turbocharger etc..
your better off setting it to OEM Spec   :wink:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline saul79
Re: Vr6 timing
« Reply #2 on: 27 February 2008, 22:45 »
they dont have dizzys on them so how can you check / alter the timing .its got a cam chain on it .
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline pink mk1
Re: Vr6 timing
« Reply #3 on: 29 February 2008, 06:25 »
hmmmmmmmm OK
but i notice that u guys (0verseas) have distributors on overhead cams......
whereas we do not have distributors on ours and it runs off wasted spark......
or coil pack mounted on the sidejust above the gearbox.
do u guys have shops where these distributors are sold !!!! and at what Cost maybe
second hand 2but with new caps and rotors
Offline Len
Re: Vr6 timing
« Reply #4 on: 29 February 2008, 08:41 »
Might be worth trying some of the Yank websites, I know Mallory do stuff for virtually any application.
www.sas.org.uk
www.the-ace.org.uk
Offline saul79
Re: Vr6 timing
« Reply #5 on: 29 February 2008, 19:11 »
hmmmmmmmm OK
on earlier vrs they have dizzys not seen any personally just worked on the later ones with coils
