Author Topic: Headlight Adjustment - Kinda urgent ish  (Read 1723 times)
Offline Mikester
  • Civic Type R
« on: 24 February 2008, 16:58 »
So i have fitted a new headlamp unit on my drivers side, along with some bright bulbs. But i dont think they are alligned properly. Short of going to a garage, what is the best way to do it? Wait til its dark and shine them against a wall and manualy adjust of what??
I has the screw things on the back that i presume you turn to adjust them?
Where about should they shine etc?
Mike
Offline saul79
Re: Headlight Adjustment - Kinda urgent ish
« Reply #1 on: 24 February 2008, 17:52 »
level in front off you lol.
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Mikester
  • Civic Type R
« Reply #2 on: 24 February 2008, 18:14 »
Well i just crouched infront of it, and tried to level it to one that i havnt changed. But i dont konw if that one is right either... hmmm
Either way they will blind people!  :laugh:
Offline saul79
« Reply #3 on: 24 February 2008, 18:32 »
take it an mot station to check it  :smiley:
Offline 95gtipete
« Reply #4 on: 25 February 2008, 10:40 »
The adjusting screw you want for height is more difficult to get to than the one just by the rad. If you look between the said light and front wing you will see a cogged wheel. Its a bit difficult so you gotta sort of put a screw driver in levering a bit at a time. Anticlockwise raises the headlight beam and counterclockwise lowers the beam. The wheel by the rad moves your beam left to right.
Offline Mikester
  • Civic Type R
« Reply #5 on: 25 February 2008, 12:34 »
Doh, i have made this mistake!
Offline patch900
« Reply #6 on: 25 February 2008, 16:22 »
I got an advisory about mine from the MOT, garage sorted em out
People still complain now though, get lots of people flashing me or looking like they are blinded by the lights  :laugh:
Guess its the bulbs in the Mk4 style lights
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline 95gtipete
« Reply #7 on: 29 February 2008, 18:24 »
passenger side headlight should be slightly higher set than drivers side.
Offline saul79
« Reply #8 on: 29 February 2008, 19:25 »
mot stations dont have someone in the car when adjusting the lights :wink: -but i see where your coming from
