Author Topic: Refurbing alloys  (Read 6732 times)
Offline admc6
Refurbing alloys
« on: 24 February 2008, 11:10 »
Does anyone have any information or pointers about refurbing your own alloys?
Offline Mikester
  • Civic Type R
Re: Refurbing alloys
« Reply #1 on: 24 February 2008, 13:28 »
There is a thread on this, ive been searching for like 10mins, cant find it, will post it when i can find it!  :cool:
Offline admc6
« Reply #2 on: 24 February 2008, 14:29 »
I did have a look but couldnt see one. That would be a great help though.
I have just spent 2hours giving them a good clean and they dont look too bad so was thinking of gving it a go myself. Its mainly the outer edge and a couple of spots inside.
I'm just not sure what the procedure is and whats best to use.
Offline Mikester
  • Civic Type R
« Reply #3 on: 24 February 2008, 14:36 »
WEll i was recommended wonder wheels, which basically is acid in a pot and a brush, and it makes a HUGE difference. Really does, and convinced me not to refurb them at all  :smiley:
Offline admc6
« Reply #4 on: 24 February 2008, 14:54 »
but surely that would only clean them, and not protect them or get rid of the marks on them
Offline Mikester
  • Civic Type R
« Reply #5 on: 24 February 2008, 14:58 »
Look at the reply to this thread, it will give you a good idea on how to refurb them:
http://www.golfgtiforum.co.uk/index.php?topic=75429.0
Mike
Offline admc6
« Reply #6 on: 24 February 2008, 15:14 »
That is a definate help.
Do you know is the paint remover that he used would take off the corrosion?
Offline boneybradley
  • Back in a Mk3...
« Reply #7 on: 24 February 2008, 15:24 »
corrosion needs to be sanded off smooth and then it will require paint/polishing
Offline Mikester
  • Civic Type R
« Reply #8 on: 24 February 2008, 15:27 »
Basically just sand it back, then use a fine wet and dry to get it back to smooth, maybe some fine filler to get it smoothened if theres any curbing. Then prime it up and spray it. Do take your time and sand back priming after each layer etc.
This thread might also help..
http://www.golfgtiforum.co.uk/index.php?topic=76105.0
Offline admc6
« Reply #9 on: 24 February 2008, 15:33 »
Where id the best place to get the spray from? Do you get just any build primer, then silver spray and then the lacquer?
This is what they are like at the moment
The one on the left i didnt gat any chance to clean before.
