Author Topic: Refurbing alloys  (Read 6734 times)
Offline admc6
Re: Refurbing alloys
« Reply #20 on: 24 February 2008, 18:53 »
I will do that. I think more peopple would be willing to try if they knew what was involved
I think i will stick with the filler for now as these dont have any kerbing its just corrosion. I might change that with the ones i'm going to take off the car
Offline admc6
« Reply #21 on: 25 February 2008, 12:39 »
Just thought on
Is there a specific silver spray you should use for your alloys?
and...
How would you get the shine back? Do you just put some polish on when its all done?
Offline Mikester
  • Civic Type R
« Reply #22 on: 25 February 2008, 12:41 »
One of two things.
Either spray them silver, metalic silver, good few layers and then laquer them and polish them like you would your body.
Or get them chromed, athough you cant do that yourself i dont think :/
Hope that helps.
Mike
Offline admc6
« Reply #23 on: 25 February 2008, 13:31 »
Oh ok, the first sounds like the finish i want.
Dont think they would look good chromed.
thanks mike you have been a big help
Offline admc6
« Reply #24 on: 25 February 2008, 21:00 »
Does anyone know what screw bit you need to split bbs rxII's?
Offline Guy
« Reply #25 on: 25 February 2008, 21:15 »
nope - but i think you need a torque wrench to do them up too?! i could be wrong but I would doubel check if I were you?
Offline admc6
« Reply #26 on: 25 February 2008, 21:25 »
i know that, but i dont have the bit i need, all but that one by the looks of it  :rolleyes:
Offline saul79
« Reply #27 on: 25 February 2008, 21:44 »
i think there 12 sided 9mm bolts
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline admc6
« Reply #28 on: 25 February 2008, 21:46 »
it sounds about right. i dont suppose you know the t number?
Offline saul79
« Reply #29 on: 25 February 2008, 21:48 »
t number ?
