Author Topic: oil temp  (Read 1917 times)
Offline cw3514
oil temp
« on: 22 February 2008, 10:53 »
what's the normal running oil temp on an AGG 8v on an 'R' plate. It used to stay around 90-94 but seems to go up to 100 and over when driving normally now. Is this right?
Offline MowatGTI
Re: oil temp
« Reply #1 on: 22 February 2008, 11:20 »
Hmmmmm.
I would say this is too high.
I have a 16v ABF engine.  My temp runs around 84-86 degrees C.
I dont gun it tho.  On a warm day, and when Im on the Motorway, sitting between 70-80mph it will rise to 90 sometimes.
Not sure if 8v engines run hotter or colder than 16v.
Offline RiCHiE360
Re: oil temp
« Reply #2 on: 22 February 2008, 11:21 »
Mines the same as above, sometimes hits 90 in standin traffic
Roofless VR6 FTW
Offline Mikester
  • Civic Type R
Re: oil temp
« Reply #3 on: 22 February 2008, 11:53 »
Mine is an 8v AGG and its hangs around 86-90. But i do gun it. ANd im always in the red of the revs.....
Offline patch900
Re: oil temp
« Reply #4 on: 22 February 2008, 12:09 »
banging it on the motorway get 90 ish, otherwise late 70-80s.
Especially at the mo cos its effing freezing
Virtually everything I know about the workings of the internal combustion engine can be written on the back of a small stamp with a large marker
Offline Mikester
  • Civic Type R
Re: oil temp
« Reply #5 on: 22 February 2008, 12:10 »
Its not a problem gettin 90 really, but this guy is gettin 100's!!!!
Oil change, and sensor change?
Offline patch900
Re: oil temp
« Reply #6 on: 22 February 2008, 12:12 »
a call to the local garage might be in order yeah
Offline Mikester
  • Civic Type R
Re: oil temp
« Reply #7 on: 22 February 2008, 12:13 »
Service might just be in order really.
Offline MowatGTI
Re: oil temp
« Reply #8 on: 22 February 2008, 12:34 »
What grade of oil do all you guys use?
Offline vdub virgin
  • If it aint broke....dont fix it!!
Re: oil temp
« Reply #9 on: 22 February 2008, 13:47 »
10w 40 semi synth
