Author Topic: Oops i have done somthing realy stupid...  (Read 3411 times)
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« on: 21 February 2008, 20:40 »
Yea   :embarassed:   When I took my drive shaft off to change the gearbox i hit it with a hammer to get it out the hub,  suddenly realising i wasn't using a copper hammer!  Now I cant get the centre hub nut on, its damaged the thread!
Stupid mistake i know!  Is there any way to fix this without geting a whole new outer CV joint/Driveshaft???  Please help  :sad:  I Can't wait to see how she drives and every time I try to get it together somthing slows me down!  :cry:
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
Offline Len
Re: Oops i have done somthing realy stupid...
« Reply #1 on: 21 February 2008, 20:51 »
Find someone with a big tap& die set!
www.sas.org.uk
www.the-ace.org.uk
Offline Rmachines
« Reply #2 on: 21 February 2008, 21:02 »
 :undecided:  I dont think i know any one who will have one that big!!   Are the much to buy?  I got a cheep small one for £3.00 totaly rubbish but it worked, i doubt they would make a BIG set that cheep!
« Reply #3 on: 22 February 2008, 12:00 »
cut 4 slots in the old nut, and pray  :grin:
this will give you a poor mans die set, but you still have to persuade it to thread on...
Offline JimR
« Reply #4 on: 22 February 2008, 13:55 »
Is it off the car? try taking it around a few engineering machine shops and get them to die it, it'll take them minutes if they have a die and will cost you zip.
Mk2 GTi.
Offline JC
  • Back in the North.
« Reply #5 on: 22 February 2008, 15:18 »
Time to get flamed here for suggesting this - but it works on Helicopters
See if you have damaged the lead of the thread - if so get a small file set and recreate it .
Sounds gash but does work  :embarassed:
« Reply #6 on: 22 February 2008, 15:29 »
doesnt sound gash at all!
Offline jammac
« Reply #7 on: 22 February 2008, 16:05 »
sounds gash to me chuff! wouldnt catch anyone doing that on civil aircraft!  :lipsrsealed:
ITS A TRAP!
Offline JC
« Reply #8 on: 22 February 2008, 16:18 »
 :grin:
nah - you'd just put the nut back on with the HAMMER instead  :tongue:
Offline Rmachines
« Reply #9 on: 22 February 2008, 17:52 »
haha i will have to take the joint off!   Do the CV joints just bang off the GTI like my 1.4?  I will take it into work on monday and see what i can do, Im sure we have a large Tap and die lying arround!  But might try the file method and file out a new thread, It wont effect the thread where the nut sits so should be fine!
Cheers!  :smiley:
