Author Topic: Mk3 GTi 8v ABS  (Read 2023 times)
Offline T3ddy
Mk3 GTi 8v ABS
« on: 21 February 2008, 14:03 »
Right, noticed that the ABS dont work on my car.
Checked and the light does not come on, on the dash when you turn the ignition on.
From my previous experience with other cars, i know that the probes at the back of the car get dirty - so im hoping its this.
Only other thing is i have noticed that a few people have commented that the pump has broken - i know how much these are so hoping its not that!
Anything i have missed or any other thoughts?
Thanks for any help - the car is a late 96 8v with an AGG.
Offline Mikester
  • Civic Type R
Re: Mk3 GTi 8v ABS
« Reply #1 on: 21 February 2008, 14:10 »
Your problem is, if the light does NOT come on when u start the car. The bulb has been taken out to avoid that fact its broken. So First put a workin bulb in, once the light comes on and stays on you know theres a fault.
Its MORE than likely that its the front sensors (i changed mine today  :wink:) They are only around £15 each from either GSF or eurocar parts. And there is a how do thread here:
http://www.golfgtiforum.co.uk/index.php?topic=57396.0
That just about covers it all, hope that helps and you can get it workin soon, but get the bulb working first.
And if you in doubt, slam the anchors on, and if u skid, its not working  :cool:
click the link...has all the answers you need..
« Last Edit: 22 February 2008, 00:05 by boneybradley »
Offline T3ddy
Re: Mk3 GTi 8v ABS
« Reply #2 on: 21 February 2008, 16:04 »
Done the "skid" test and yep its not working.
The bulb USED to work - it did when i bought the car!
Offline Mikester
  • Civic Type R
Re: Mk3 GTi 8v ABS
« Reply #3 on: 21 February 2008, 16:14 »
In that case, get yourself a multimeter if you dont have one, and test the sensors as shown in the thread i linked you.
I tested my front 2 yesterday with a multi meter (longest part is gettin the wheel off!!)
Bought a new sensor today and fitted it, now my light goes off, and abs works fine.
So yeah, new bulb, then multi meter them to test the resistance, the one that is lower that 1.0khm or over 1.3khm or peaks around is broken.
Offline golf-gti-matt
Re: Mk3 GTi 8v ABS
« Reply #4 on: 21 February 2008, 17:08 »
The ABS light should come on when you turn the ignition on then go out after about 3 seconds after the engine has started.  so if the bulb isnt coming on when you turn the ignition on then the bulb is either missing or blown.
Offline beni-iow
Re: Mk3 GTi 8v ABS
« Reply #5 on: 21 February 2008, 21:40 »
hi i had this problem with my 96 8v gti the bulb had blown and abs did not work.got a new bulb and the light came on and stayed on.i used my mates vag com diagnostics and had a front o/s speed sensor fault.got a new 1 from gsf at just under a tena (im in the parts side of motor trade) fitted it took no more than 30 mins and voilla its all fixed now.
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: Mk3 GTi 8v ABS
« Reply #6 on: 22 February 2008, 01:26 »
dus the bulb actually remove separately then from teh abs light area??
as i had to change the complete plastic uni as i chekd it out n seemed the bulb was soldered on a circuit board???
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline Ruji
Re: Mk3 GTi 8v ABS
« Reply #7 on: 22 February 2008, 01:28 »
oh n by the way...av got 2 new front abs scensors goin if anyone interested..turns out i didnt need the fronts wen i got it up on vag com.
one v my rear ones are gon.i dint even no i had rear ones...dont rmemba spottin em wen i changed he springs!?
oh wel...or if anyone wants to trade the fronts for rears!?
Offline beni-iow
Re: Mk3 GTi 8v ABS
« Reply #8 on: 22 February 2008, 08:24 »
i got a new bulb solderd in on mine
Offline Mikester
  • Civic Type R
Re: Mk3 GTi 8v ABS
« Reply #9 on: 22 February 2008, 12:01 »
Yep, you can just solder a new one in. Or there is a whole unit for sale in the for sale threads.
