Author Topic: what does this hook up to??  (Read 2671 times)
Offline BobbyT
« on: 21 February 2008, 13:53 »
i have this in my car but what should i connect the blue wire to? cheers
Offline Mikester
  • Civic Type R
Re: what does this hook up to??
« Reply #1 on: 21 February 2008, 15:05 »
I removed the whole unit of that and it stilll works fine. But when it was plugged in there was a blue cable from the headunit......
Its an amplifier?
Offline Horney
« Reply #2 on: 21 February 2008, 15:08 »
Signal amp for FM/AM?
Nick
Offline remapped
  • If you are going through Hell, keep going
« Reply #3 on: 21 February 2008, 16:40 »
am sure that amps the FM signal
if not mistaken i connected the blue lead to then head units power antenna lead
OEM(ish) G3GTi 8v5dr
Offline Mikester
  • Civic Type R
« Reply #4 on: 22 February 2008, 00:42 »
Yeah, well i removed mine and it still gets a fine signal. But i think it just goes to the ignition power lead.
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
« Reply #5 on: 22 February 2008, 01:12 »
it seems common practice for a lot of the VW family to have these in there cars when they change to an aftermarket head unit.
something to do with the loss of signal strength wen removing the factory fitted one.wierd.
a lot of the dubs are stil fine without em but theyr always recommended to put em in.
i have a mk3 golf gti...wen i bought it.....it cum complete wiv a decent but non mp3 sony head unit...and wen i removed it to look at the back v it..i noticed i had one too.]
the majority of dubs i'v removed radios from have had em in.even sumtimes rigged up to the factory fit radios.
the lil blue wire goes to the radio remote....its a lil amp in essence and needs its own power supply.
the aerial itself plays the ground and the blue wire to live...but use the remote output from the radio or the "att" being the electric antenna output...same thing pretty much..it jus assures that its only active wen the radio is turned on.
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
Offline BobbyT
« Reply #6 on: 22 February 2008, 09:36 »
cheers guys, will get this hooked and see if it works  :smiley:
Offline BobbyT
« Reply #7 on: 06 March 2008, 10:35 »
right got round to connecting this wire up to my head unit and now i have full reception! result, i guess the stubbys do pick up like stock!  :wink:
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #8 on: 06 March 2008, 10:38 »
good stuff!
Offline lee_lee08
  • 1996 GTI 8v
« Reply #9 on: 25 March 2008, 10:41 »
That thing got ripped out of my car!
It was stopping my stereo from turning on! there was too much noise frequency interupting with the power to my stereo. I ripped it out plugged it in normally and it all works fine. apparently theres an earth running through the aerials on VWs
My stereo will not turn on with out my aerial connector plugged in! Weird huh? and with that aerial booster connected it wouldnt come on at all!
