Author Topic: mk3 gti 16v ISv  (Read 2506 times)
Offline tim145tim
  • 1997 GOLF GTi 16v ANNIVERSARY Mystic Blue Pearl
mk3 gti 16v ISv
« on: 20 February 2008, 13:27 »
Hi guys where is the ISV?
whats it look like?
how do you all recommend cleaning it?
Offline Pete Taylor
Re: mk3 gti 16v ISv
« Reply #1 on: 20 February 2008, 17:59 »
Take off the ignition leads from the black plastic tray then remove the 3 allen head bolts, you'll see the ISV under there, leave it soaking in petrol to clean it
Offline tim145tim
Re: mk3 gti 16v ISv
« Reply #2 on: 20 February 2008, 19:36 »
Would a good zap with carb cleaner do the trick?
Offline nelds
  • Now Golfless but owning an Audi still counts
Re: mk3 gti 16v ISv
« Reply #3 on: 20 February 2008, 19:38 »
what is an ISv and what does it do.... :grin:.. ( i cut hair for a living).... :grin:....benefits from cleaning..??
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: mk3 gti 16v ISv
« Reply #4 on: 20 February 2008, 23:34 »
ISV=Idle Stabilization Valve, helps memter enough air for the engine to idle. If broken or dirty can cause a bad/unstable idle or cause your car to stall.
I cleaned mine out on my 16v with Wynns carb cleaner, just kept sprayin it in there till what came out was clear and not oily/mucky.
Offline oggy
Re: mk3 gti 16v ISv
« Reply #5 on: 21 February 2008, 10:20 »
Acetone, white spirit, carb cleaner, petrol - any decent solvent will so, just make sure it doesn't react with the gaskets involved. The important thing is that the sliding valve is free to move at all times. Spray with light oil after cleaning.
Offline tim145tim
Re: mk3 gti 16v ISv
« Reply #6 on: 21 February 2008, 18:08 »
try lawyer
I though the whole point of this forum was that people that are on here all the time can help out those who dont have the time to fiddle around with their cars 24-7?
« Last Edit: 21 February 2008, 18:21 by tim145tim »
Offline eightyeightmph
Re: mk3 gti 16v ISv
« Reply #7 on: 22 February 2008, 14:17 »
try lawyer
Dude! Chill pill, I think he was refering to himself! :rolleyes:
2016 GOLF GTD
