Author Topic: RNS 510 Sat Nav with Parrot install - with PICS!  (Read 8696 times)
Offline TagnuT
  • Edition 30
Re: RNS 510 Sat Nav with Parrot install - with PICS!
« Reply #10 on: 19 February 2008, 21:26 »
BTW - what's the small circle/indent on the upper right corner of the unit trim for ?
Cass
that will be the alarm intermittant red flashy when you lock up..... ?
Is it a light sensor to change the brightness of the display and to change it over to "night time" theme colour scheme?
Bye Bye Edition 30
Offline 2007GTI
« Reply #11 on: 19 February 2008, 23:37 »
re: 26 degrees, I knew someone would pick up on that, I turned it right up as i just got in the car to take pics and it was freezing!
re: small circle spotted by cass, no idea, could be light sensor, but then again it could be an LED...
Offline synnea
« Reply #12 on: 20 February 2008, 08:43 »
Lovely unit - just wish they would come down in price a bit. Re the firmware update when they fix the postcode issue - can you update the firmware via the SD card once the unit is installed or how else does the update work?
R32 : DBP : Lux Pack : Winter Pack : Cruise : Leather : Parking Sensors : Rear Tints : Armrest : RNS 510 : Ipod MediaIn : FreeView Tuner : VagCom
Offline 2007GTI
« Reply #13 on: 20 February 2008, 09:39 »
I believe you have to use a CD/DVD from VW to update firmware.
Offline duzza
« Reply #14 on: 20 February 2008, 10:41 »
Thats right, beware however if you have 'misplaced' your maps DVD after saving the content to the hard drive as I believe flashing the firmware wipes the map content  :nerd:
GTI Edition 30, Metalic grey, MFD2, Highline, R32 Wheels
Offline 2007GTI
« Reply #15 on: 20 February 2008, 11:59 »
that true too, you need a MAPS DVD after firmware update.
Offline DrT
  • GOLF GTI
« Reply #16 on: 20 February 2008, 20:14 »
want one  :smiley: :smiley: :smiley: :smiley:
DrT
Golf GTI, 3d, Diamond Black, 06 Reg, Basic and Fun.
Offline SKAVIA
« Reply #17 on: 07 March 2008, 22:44 »
Unit looks slick but I thought the RNS 510 has bluetooth built in? Hence you wouldn't need the Parrot kit as well?
Offline 2007GTI
« Reply #18 on: 07 March 2008, 22:46 »
No, bluetooth is not as standard on the RNS 510.  It is an option in Europe but not in the UK.  For retro install, you have to buy a separate box and install it under the seat.
loads of info here:
vwnavi.com
Offline 2007GTI
« Reply #19 on: 07 March 2008, 22:49 »
Update to this answer, I updated my firmware from 0520 to 1020 and it did not wipe the maps or data on the drive.
