Author Topic: 225/35 or 235/35?  (Read 4462 times)
Offline L555BAT
225/35 or 235/35?
« on: 19 February 2008, 10:20 »
Looking at getting a set of 19"x8" wheels, but unsure as to correct tyre size.  Should it be 235/35/19 or 225/35/19?
Any ideas?
Cheers.
Offline hufcforpromotion
Re: 225/35 or 235/35?
« Reply #1 on: 19 February 2008, 10:41 »
225 35 19" to keep the rolling radius correct and to prevent having any problems if you lower your car!
VW Golf MKIV R32. Anthricite Grey.
Offline The Wheel Man
« Reply #2 on: 19 February 2008, 13:16 »
2nd that.
The standard tyre diameter on a 225/40/18 is 637mm
Upgrade on a 235/35/19 Diameter is 647mm
Upgrade on a 225/35/19 Diameter is 640mm
You can use a 235 but its not ideal.
Offline martininwillerby
  • Golf GTD DSG
« Reply #3 on: 19 February 2008, 16:33 »
I've been advised that 235/35/19 are the correct tyres due to the loading of the tyre....
225/35/19 are usually 88Y and 235/35/19 are 91Y.
OEM / Standard tyres 225/40/18 are 92Y for the GTI not 225/40/18 88Y which some tyre fitters will try to sell you..
martininwillerby
Golf GTD DSG, RSN510, DAB, Bluetooth, Leather, 18" Charleston Shadows, Park Assist And In The Best Colour... White.
Martininwillerby
Offline datracer99
« Reply #4 on: 19 February 2008, 21:21 »
The difference in rolling diameter is less than 2%, so i wouldn't worry about it. It just makes the speedo a little less inaccurate.
What offset will the wheels be? That will also effect whether they are likely to rub or not.
  • Golf GTD DSG
« Reply #5 on: 19 February 2008, 22:26 »
Correct off set would be OEM.... ET51/ET54
I'm getting ET50.
Some with ET45 have rubbing issues.
Martininwillerby
Offline datracer99
« Reply #6 on: 20 February 2008, 02:51 »
With 235s on 50 offset, should look sweet  :cool:
should not have clearance issues unless you go too low.
Offline neg
« Reply #7 on: 20 February 2008, 11:19 »
I have 235/35/19 running on BBS CH's and they are perfect and what is recommended.
  • Golf GTD DSG
« Reply #8 on: 20 February 2008, 16:40 »
NEG... do you have any pic's of your car with the 19 BBS CH's. Have you had to get it lowered for the right look....
Martininwillerby
Martininwillerby
Offline neg
« Reply #9 on: 20 February 2008, 17:19 »
I do indeed on both accounts, will PM you
