Author Topic: removing clocks  (Read 1459 times)
Offline ginga
removing clocks
« on: 18 February 2008, 22:58 »
dont know if already been a thread cant find it but i need to take the speedo clocks out. how do i do it? thanx
Offline Ben Lessani
Re: removing clocks
« Reply #1 on: 19 February 2008, 10:28 »
Its really easy, pretty much start dismantling the upper dash.
Remove steering wheel
Remove stereo
Pull heater control dials/levers off
Undo screws to upper and lower dash
Remove the switches for lights, fogs etc.
Withdraw the dash facia, then theres 3/4 screws above and below the speedo holding it in
Pull the speedo forward, then with your left hand, stick it behind the gauges and squeeze the clip for the odo and pull it out, be careful the locating pin doesn't fall out.
Reach under the dash and undo the 1/2 electical connectors off the bottom.
Pull the clocks out.
Kinda like this,
« Last Edit: 19 February 2008, 18:06 by blessani »
Re: removing clocks
« Reply #2 on: 19 February 2008, 13:39 »
there is an FAQ for this, go have a look ;)
Offline bigman_10
Re: removing clocks
« Reply #3 on: 19 February 2008, 16:41 »
like blessani said but i'd just remove the steering wheel first to make acess to the screws easier  :wink:
Offline ginga
Re: removing clocks
« Reply #4 on: 19 February 2008, 19:31 »
ooh yeah that looks fun :undecided: cant these faq's anywhere
Alpinehead
Re: removing clocks
« Reply #5 on: 19 February 2008, 19:49 »
iv had my dash out a few times now..  i have never taken my steering wheels off.   its prob easyer but i had no probs removing all the screws and putting them back.
you just have to be gental!!!
Offline veedubmk2golf
Re: removing clocks
« Reply #6 on: 19 February 2008, 21:12 »
I' disconnected the battery to m8 to be on the safe side as you'll be messing with a lot of important wires. I didn't remove my steering wheel but have done in the past and it is an easier job with it off.
Offline ginga
Re: removing clocks
« Reply #7 on: 19 February 2008, 21:21 »
cheers geezers im gonna try it this weekend. need to find out why my miles arent going up. thanx
Offline nealey
Re: removing clocks
« Reply #8 on: 19 February 2008, 21:55 »
ive never tried doing it with the steering wheel off but it is possible with it on still
Offline bigman_10
Re: removing clocks
« Reply #9 on: 19 February 2008, 21:59 »
ok maybe taking the wheel off isn't essential :grin: i've not done it with it on but i think it would give a bit more room for access! oh well shows haynes isn't exactly a bible!
