Author Topic: sub in the boot floor? suggestions/advice  (Read 2611 times)
Offline cняis
« on: 18 February 2008, 16:38 »
i have an unbranded bandpass sub box with 2 x 10" subs, which causes 2 problems:
1. its a large box and doesnt provide me with much shopping space in the boot.
2. it creates a LOT of bass, i.e. it will give you a headache but its not overly crisp/responsive (drones a bit!) - i think thats the nature of bandpass boxes.
as this is for the project golf, which will see limited milage, i can do away with the spare wheel. i'd like to make a false floor (mdf) in the boot and mount the a sub over the spare wheel well. will this:
a) sound ok?
b) need to be ported?
b) mean that the wheel well needs dynamat (or similar)?
im not after a show winner, and i would like to re-use what I have already. im just looking for value for money.
 :nerd:
Offline Uruk Hai
Re: sub in the boot floor? suggestions/advice
« Reply #1 on: 18 February 2008, 17:02 »
With any sort of build like this sound proofing is good idea and you would probably end up having to make a false boot floor to create enough space to fit the sub, I would try and find out how much space the subs you have need to try and get the best sound out of them. I have no idea what it would sound like and I wouldnt worry about porting it as the chances are you wont be able to make the space it'll be in completely air tight.
Offline cняis
« Reply #2 on: 18 February 2008, 18:24 »
ok, sounds good. im just after a little punch to back up my 17cm front speakers, as i wont be fitting 6x9s (i'd like to strip the rear out)
Offline vr4000d
« Reply #3 on: 18 February 2008, 19:17 »
go for sealed as box size will be smaller.
sound proofing is a good idea.
sound quality can vary from so many factors so hard to say but should be ok ;)
Offline mk2mark
« Reply #4 on: 18 February 2008, 19:18 »
Agreed. I'd also go for a fibreglass enclosure.
Offline Hurdy
« Reply #5 on: 18 February 2008, 19:39 »
I'd initially thought about going this way and having one of those bottle repair kits instead of the spare. I've now gone against it and started a side panel moulding off. Bl00dy messy, but I'm hoping it'll be worth it. I'm going for a sealed rather than ported box to keep the bass tighter. :cool:
Seat Leon Cupra Black 290 DSG
Offline Heyho
« Reply #6 on: 18 February 2008, 20:25 »
I would FG the spare wheel well, then keep going up with the false floor until you have the desired volume.
Offline russ-vdub
  • Once a Dub, Always a Dub
« Reply #7 on: 22 February 2008, 10:39 »
a lot cheaper solution would be two of these:
http://audiostarwholesale.co.uk/upimgs/JBL_BassProII.jpg
under drivers and passenger seat mounted flat
just an idea to save time and money
Offline Len
« Reply #8 on: 22 February 2008, 13:13 »
There was a very good post/thread about this a while back. The guys solution was good so its worth trying a Search for!
he used a false floor as well.
www.sas.org.uk
www.the-ace.org.uk
