Author Topic: Bigger Wheels vs Bumpy Ride ?  (Read 3576 times)
Offline ghockle
« on: 16 February 2008, 09:08 »
Have you added big fat wheels and tyres to your car  :cool: ?
Was it worth it ? or did you perfer the ride before ?
How has the ride quality changed ?
Do you now feel every bump or is it just slightly different to the original set up ?
Thanks
Offline gooseuk
  • Diesel is the way forward
Re: Bigger Wheels vs Bumpy Ride ?
« Reply #1 on: 16 February 2008, 12:24 »
Well the ride i would say is a tad different and it feels like you lost a bit of accelearation. But after few weeks you dont notice it lol.
Diesel power all the way
Offline ghockle
« Reply #2 on: 16 February 2008, 12:40 »
cheers - so how diiferent ? whats diferent about it ? heavier steering ?
Offline 1688bran
« Reply #3 on: 16 February 2008, 12:49 »
   i find the steering jus a bit  lighter only just tho ..... it jus a little bumpier and on uneven road occasionally u will get a slight pull fto one side depends on which side the road is uneven to .... i also find is i got a little bit more road noise too .... but im happy with it wont go back to the little wheels i got b4 ..lol   im running 235/35/19 front and rear
Offline gooseuk
« Reply #4 on: 16 February 2008, 14:31 »
Well with me. I find that u feel things more like bumps and that. Not so much u wanna destory the car lol but a slight difference. Also you hear more noise comming from the tyre. But i belive that because there cheap tyres and more likley to create more noise.
Improved grip is a bonus also.
Offline ghockle
« Reply #5 on: 16 February 2008, 14:38 »
so would you say the handling improves with larger wheels and tyres ?
Offline gooseuk
« Reply #6 on: 16 February 2008, 15:33 »
I say so. I could feel the limit going around corners with other wheels. But not so much with bigger ones. But cheaper tyres suck
Offline 1688bran
« Reply #7 on: 16 February 2008, 16:01 »
 is pirelli P zero rosso cheap ..... thought they are quite a god make ! what tyres u got then ??? i think the lower profile u go down the more bumpier it gets
Offline richw911
« Reply #8 on: 16 February 2008, 16:57 »
I run 225/40/18 and yes it is a bit more bumpy than stock but as 1688bran said you will always get this with lower profile tyres. Nothing too bad IMO - well worth doing :afro:
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #9 on: 16 February 2008, 21:27 »
I'd say the wider 225/40 18's had more grip on the fast, sweeping bends (A road surfaces), but not as much agility or acceleration as the 205/55 16's due to the extra 'unsprung' weight.  The 16's are also best for country, B type road thrashes (not as crashy).
Next up for me to try, are some 17's with 215 45's on. :wink:
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
