Author Topic: VW 'slotted socket' tool?  (Read 2080 times)
Offline Pugwash
« on: 15 February 2008, 22:40 »
Doing suspension next week and was reading the manual, as first time anywhere near the suspension. Says i will need a special VW tool 'slotted socket' to fit back on the upper retaining nut on the front. Stop the strut spinning while tightening the nut. Is this essential or can i manage without this? Maybe use something else? If not were would i get one of these tools from? Would appreciate any feedback... Like i sadi this is my first time on the suspension, will there be anything i may fid helpful from you guys before i start? Read uthrough a few threads and they are very helpful..
Pugwash
Offline filthy
Re: VW 'slotted socket' tool?
« Reply #1 on: 15 February 2008, 22:44 »
I got a piece of steel tube, think it was 1/2 inch, but may have been 5/8, cant remember, then cut some away to leave 2 prongs, bent the pipe 90 degrees to get some leverage, and jobs a good'un, cost nothing and took 5 mins to make
Having trouble keeping it on the straight and narrow?  www.powersteeringstore.co.uk
Offline Pugwash
« Reply #2 on: 15 February 2008, 23:24 »
nice one mate.. great advice. :smiley:
Offline saul79
« Reply #3 on: 15 February 2008, 23:26 »
get em on ebay for a couple off quid
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Grim_Reaper
  • warningz...i haz powaz
« Reply #4 on: 16 February 2008, 21:36 »
is this the nut you tighten with the allen key??? if so then i used a big flat head screw driver to stop the shock from spinning, while i got someone else to tighten it
Offline saul79
« Reply #5 on: 17 February 2008, 00:00 »
they dont have em on mk3's there 18mm nuts -unless its an earlier mk3 then i dont know if they have the slotted nut
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
« Reply #6 on: 17 February 2008, 00:57 »
I recoment splashing out of the tool, it all adds to your tool kit! but if you dont want to wait for delevery a DIY one like filthy says will do the job fine!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
