Author Topic: Cambelt and Waterpump  (Read 1170 times)
Offline Ciderdan
« on: 15 February 2008, 17:02 »
Think they are on their way, are they both easy to change??
cheers
Keep the Faith
Offline leavingeasy
Re: Cambelt and Waterpump
« Reply #1 on: 15 February 2008, 17:10 »
Depends how you are with spanners.
water pump is pretty simple but be careful with the cambelt if you have never done it before, simply misaligning by one or two teeth could result in bent valves.
coming to some armco near you soon.....
Offline Ciderdan
« Reply #2 on: 15 February 2008, 19:06 »
thanks very much, will get onto it at some point soon!  :huh: is gsf the best place for parts?
Keep the Faith
Offline herbster
« Reply #3 on: 16 February 2008, 00:19 »
all down to preference, some bits are easier from gsf or euro but i find local factors just as good and priced right plus they deliver for free!! if you get a garage to do the timing belt looking at 100-150 quids and piece of mind if it goes wrong!!!
FAB is my life and the CABRIO's the wifes!!!!
Offline dadrathers
« Reply #4 on: 16 February 2008, 14:22 »
Just had water pump and timing belt and tensioner changed at the garage. Water pump was completely knackered and had timing belt replaced for safety sake. Amazing difference in the noise level with the new pump. Expensive though £343.
Offline Ciderdan
« Reply #5 on: 16 February 2008, 19:30 »
£343??? i reckon i'll do it myself next weekend  :tongue:
Keep the Faith
Offline dadrathers
« Reply #6 on: 16 February 2008, 21:49 »
Actually that did include an MoT as well - btw it passed with no advisories. There was 5 hours labour so I guess they found it quite a big job. I have been using this garage for some time so I know that they would not rip me off.
Offline Ciderdan
« Reply #7 on: 16 February 2008, 22:06 »
fair enough... after just buying her i cant really afford for someone else to do it, although i would prefer it  :tongue:
Keep the Faith
« Reply #8 on: 18 February 2008, 12:43 »
you wont bend valves on an 8v unless you have a lairy cam in it, check my digifant FAQ for info on how to tune it afterwards, its not like these old bug engines where you can just set it by ear ;)
Offline Organisys
  • Old and Slow...
« Reply #9 on: 18 February 2008, 12:47 »
Be aware GSF vary in quality alot, I had a water pump from them that only lasted a few months before the bearings went.
 :smiley:
