Author Topic: NEED HELP - Fitting FK Lower Vents ...  (Read 2168 times)
ShoCk
« on: 14 February 2008, 15:12 »
How the f*ck (sorry for the foul language) do I remove the old vents? I managed to remove the passengers side and its in a million pieces and ive grazed my knuckles and everything ... Dont want to attempt the other side until I find out exactly how their removed ...
Also how the hell do I fit the FK ones? their so hard ... dont want to clip in!?
Any advice regarding this would be appreciated ... thanks.
Offline Mikester
  • Civic Type R
Re: NEED HELP - Fitting FK Lower Vents ...
« Reply #1 on: 14 February 2008, 15:26 »
There is 2 pins that slot into the bumper on the bottom and the top has like a clip i think. I had the same problem. You have to kinda pull the top down and then it comes out. But they are flimsy as you like, so its a bit fiddly. failing that a pair of pliars, lol!
ShoCk
« Reply #2 on: 14 February 2008, 16:31 »
Arghh ... thats exactly how I removed it though and it was so difficult!!!! :(
How do I fit the FK Vents?? any one know ...
Offline Len
« Reply #3 on: 14 February 2008, 16:46 »
Had a screw fixing in the top of mine (the old vents)
www.sas.org.uk
www.the-ace.org.uk
ShoCk
« Reply #4 on: 14 February 2008, 18:16 »
Im sure their were a few people here that fitted bonrath/fk lower vents ??? any input from you guys/gals?
Offline BobbyT
« Reply #5 on: 14 February 2008, 18:36 »
took me 5 mins! lol  :smug:
the top bit clips in (i had to remove two nuts that where in the way) and then the they clip in at the bottom on the lip
ShoCk
« Reply #6 on: 14 February 2008, 20:25 »
Are you kidding me??? why am I finding it so hard :(
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #7 on: 14 February 2008, 22:21 »
I replaced the drivers side on mine cos it was missing, i seem to recall i layed on floor in front of bumper, passed the grill behind bumper, had the bend the horn a bit to get it past but then it just clipped in bottom then seated nicely into top, took about 5 minutes to fit
Offline Mikester
  • Civic Type R
« Reply #8 on: 14 February 2008, 23:02 »
Yeah i bent my horn out of the way to get my air feed down there!
Offline saul79
« Reply #9 on: 14 February 2008, 23:07 »
same here just made one hole for the 10mm bumper bolt larger to get it in dont line up for crap though and used a self tapping screw
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
