Author Topic: Suggestions on rear abs sensor replacement?  (Read 2096 times)
Offline terri8le1
« on: 13 February 2008, 17:37 »
Took me wheel off today to have a go at changing the rear abs sensor, got to the allen bolt and it was so rusty and sh!tty, i even think it may be slightly rounded, but i cant get to it very good as i aint got a ramp, just the standard jack.
Any suggestions what i could do about the allen bolt? :sad: Reaaly dont want to be paying anyone to do it as it seems such a straight forward job!
kells
Re: Suggestions on rear abs sensor replacement?
« Reply #1 on: 13 February 2008, 17:39 »
go buy somke axel stands first
then spray wd40 on it, go for a brew then try again
also try hammer your allen key in to the bolt so its seated in propperly
Offline terri8le1
« Reply #2 on: 13 February 2008, 17:43 »
Yeh its a pain tryin to hammer it in as the suspensions in the way to get a good swing. I'll have another go tomorrow i think with the wd40. Cheers
kells
« Reply #3 on: 13 February 2008, 17:55 »
is it the bolt that holds part of the caliper on (2 of them)?
if so
u can get a hammer on them just, did mine on the weekend, i had to remove the braket that supports the handbrake cable, then i had to use the hammer to hit the allen key stem to actually loosen the bolt (once id got the allen key seated in the bolt)
Offline terri8le1
« Reply #4 on: 13 February 2008, 18:23 »
Nah, just the small allen bolt that holds the sensor on. Would you recommend takin the caliper off to change the sensor?
kells
« Reply #5 on: 13 February 2008, 18:28 »
i would yes if it will give u more space to work with, to remove the caliper is really easy... once you free the bolts, u also have to release the handbrake cable but its not hard, a bit faffy and thats it
Offline terri8le1
« Reply #6 on: 13 February 2008, 18:37 »
Alright, nice one mate, i'll give it a go :wink: Cheers
Offline Pete Taylor
« Reply #7 on: 13 February 2008, 19:26 »
Don't take anything off! There's just about enough room to hammer a socket head over it and use the ratchet to take it out. Get a replacement bolt though (have a look round the engine bay and nick one from there and swap them over)
Offline terri8le1
« Reply #8 on: 14 February 2008, 16:06 »
Couldnt use a socket tho as its just a round allen bolt is'nt it?
kells
« Reply #9 on: 14 February 2008, 18:02 »
get a allen key socket for your socket set if that makes sense :wink:
