Author Topic: what to do with the engine?  (Read 1062 times)
Offline dubsport
  • TDI POWAR!
« on: 13 February 2008, 13:31 »
ok going to start cleaning up / replacing parts of the engine on the GTI ... what do you guys do when you get a new car? she wont be being driven til july (when im 20) so should i buy and fit new sparks and such now or leave it til july? how do i 'flush' the engine etc?
thanks hope this makes sense  :smiley:
Edit: pic of the engine bay as it is now,
« Last Edit: 13 February 2008, 15:39 by dubsport »
Offline MarkS
Re: what to do with the engine?
« Reply #1 on: 13 February 2008, 13:37 »
Maybe a basic service?
Spark plugs, filters, leads and the like?
Do you mean an oil flush?
I used some Wyatt's flush when I got my car.
Worked well, but I heard that it can dislodge particles that are otherwise keeping the oil from leaking out of various places  :undecided:
Either way, you can't go far wrong with an oil change  :smiley:
Is the car insured at all now?
So you could maybe take it for a run every few days just to keep all the parts moving until july?
Offline dabill
« Reply #2 on: 13 February 2008, 14:15 »
first thing is to give the engine bay a damn good clean, get some enginebay cleaner from halfrauds, tape all the electrics up and make sure nothing is showind that cant get wet. then sray copious amounts of cleaner around, then start scrubbing with a good stiff brush, i used several as they soon clogg up, then jetwash the engine down, and repeat until all components and engine bay is shiny, good 2 or 3 times usually does it.
once thats done, plugs leads and oil, general service, but if it aint broke, dont fix it is what i say.
off with the altenator, give that good wire brushing, clean all the contacts up and make it look nice.
could even do the rocker cover while your in the mood, pop it off, and wire brush/sand it down nice and smoothe, then a few coats of hammerite and your sorted.
you may want to replace the air pipes on the top of the head, if their old, they may have perished slightly and probs could do with a change. but like i say, if they dont look too bad, leave them and spend on something else...
thats a bit to be getting on with...
rob
noble tuned - and still not fast enough!
Offline Conker
« Reply #3 on: 13 February 2008, 19:12 »
Whip off all the fluid tanks and give them a scrub too e.g. the coolant (will need a flush as well) and the windscreen washer. You could also consider doing the power steering and brake fluids while you've got the time for it to be off the road.
Offline dabill
« Reply #4 on: 13 February 2008, 22:43 »
buy a battery cover too!
Offline bigman_10
« Reply #5 on: 13 February 2008, 23:52 »
i'm just about to paint my rocker cover red it obviously does sweet F A for the performance but it looks nice! maybe try looking at neatening up the pipes and hoses looking at if you can arrange them in a neater way? just an idea   :wink:
Offline vwjack
« Reply #6 on: 14 February 2008, 00:36 »
dude your ht leads are like spaghetti all nuffed up!
rocker cover need painting.
and defo clean it up.
Offline dabill
« Reply #7 on: 14 February 2008, 09:24 »
and the fan guard on the radiator, take that off and give it a good sanding and paint with hammerite! or if it was like mine and crumbleing at the bottom cos of rust, go to ECP or GSF and get a new one, give it a coat of primer then hammerite.
