Author Topic: Issues with 1 of my wheels.  (Read 2330 times)
Offline Mikester
  • Civic Type R
« on: 11 February 2008, 16:05 »
Friend thought it was cool to put some alloy wheel cleaner on ONE of my front wheels (it was a girl) and now its basically welded all the brake dust to the wheel in patches, today (good 2 weeks later) i go to clean the car and notice this. SO i start with a sponge, no luck, then a scourer sponge, no luck, then a full on wire brush, and it wont move. Is it f**ked???
cheers
Pic:>>
Offline brisdriver
Re: Issues with 1 of my wheels.
« Reply #1 on: 11 February 2008, 17:12 »
Naah, use more alloy wheel cleaner on it, leave it for a minute then scrub and rinse should be fine,
<a href="http://photobucket.com" target="_blank"><img src="http://i215.photobucket.com/albums/cc311/brisdriver/30-10-07_1419.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a><a href="http://photobucket.com" target="_blank"><img src="http://i215.photobucket.com/albums/cc311/brisdriver/06-11-07_1537.jpg" border="0" alt="Photo Sharing and Video Hosting at Photobucket"></a>
Offline nelds
  • Now Golfless but owning an Audi still counts
« Reply #2 on: 11 February 2008, 17:45 »
smack da b!tch up n send her back to the kitchen.......WOMEN, KNOW YOUR LIMITS !!!  :grin:
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 11 February 2008, 17:48 »
yeah give it another clean...unless its wonder wheels as that eats anything it seems to come in contact with (including its own bottle!!).... if its burnt the lacquer its time to rub down and repaint and time to kick her tits in!!  :wink:
Offline Guy
« Reply #4 on: 11 February 2008, 17:56 »
from the fact that your nut covers are white i'd say that you'd been using wonder wheels already???  :rolleyes:
move over to something like meguairs hot rims which does the job of lifting dirt without wrecking your wheels... and no wire brushes!
you can get hot rims in halfrauds too
kells
« Reply #5 on: 11 February 2008, 18:04 »
i tried the meguires, and like alot of their range i thought it was over rated and over priced, for wheels their really is only 1 and thats wonder wheels, use it correctly and it does the right job
the rim will clean up fine i would think, as said before give it another clean
Offline Guy
« Reply #6 on: 11 February 2008, 18:14 »
wonder wheels is very acidic and damages lacquer - it will eat into any damage in the lacquer that there is  - i learnt the hard way from constant use of the stuff
it IS stronger and cheaper but I would avoid continued use....  hot rims you can use all the time
both should be able to shift that lot anyway  :smiley:
kells
« Reply #7 on: 11 February 2008, 18:33 »
thing is tho....should only ever have to do them once a year at most if you wash your wheels once a week.... so for me at least wonder wheels is the only thing id ever use, lasts years does 1 bottle..
and the not as strong stuff is a waste of time for badly soiled wheels, you would be their forever trying to clean your rims hahaha :laugh:
wonder wheels does say on it, dont use on cracked lacquer...as u say it is acid based, good stuff :cool:
Offline saul79
« Reply #8 on: 11 February 2008, 18:53 »
get the dremel on em :smiley:
mk3 golf 1.8t ,280mm front brakes rear disc conversion,coillies.
Offline Guy
« Reply #9 on: 11 February 2008, 22:28 »
ah haa... but people use it weekly (like i once did) because it imparts such a strong clean... and then after a year their alloys are fcuked!   i found the megs was more kinder to use on a regular basis
to give megs it's due it ain't too shabby...
