Author Topic: wheels et help  (Read 1206 times)
Offline Diluxe
wheels et help
« on: 10 February 2008, 21:21 »
Hi i'm currently running 6*14" ET35, have seen some rims that i like the are 6.5*16 ET43, other than keeping the rolling radius the same,can anyone seen an issue with the ET on a mk2?
cheers
1997 16V
Offline takethefifth
Re: wheels et help
« Reply #1 on: 10 February 2008, 21:44 »
They'll sit quite far in, 10mm spacers will push it out to a more reasonable ET33.
Offline mk2mark
Re: wheels et help
« Reply #2 on: 10 February 2008, 23:47 »
Yep, 10mm spacers job done.
Offline Diluxe
Re: wheels et help
« Reply #3 on: 11 February 2008, 22:53 »
i was just about to obuy this
http://cgi.ebay.co.uk/10mm-spacer-kit-Audi-a3-a4-a6-a8-tt-rs4-rs6-etc-kit1_W0QQitemZ290205194915QQihZ019QQcategoryZ122154QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
but then the guy started on about wheel wobble? do i need to go for the more expensive spacers?
1997 16V
Offline monzablue16v
Re: wheels et help
« Reply #4 on: 11 February 2008, 23:07 »
For a mk2 they are 4 stud x 100 PCD unless you put mk3 stuff on, hubcentric spacers are the ones that stop wheels wobbling. :)
Offline Diluxe
Re: wheels et help
« Reply #5 on: 12 February 2008, 10:23 »
yep i'm going 5 stud mk3 widetrack, so i will definietly get whell wobble if i dont get the hubcentric ones?
1997 16V
Offline mk2mark
Re: wheels et help
« Reply #6 on: 12 February 2008, 15:29 »
Probably not on 10mm spacers. That guy is covering his arse, you should be ok.
Re: wheels et help
« Reply #7 on: 13 February 2008, 12:51 »
non centric 10mm ones are fine, plenty of hub lip left sticking out for the wheel to centre on.  bigger than around 12-15 is where you start to need hub-centric.
