Author Topic: mk1 gti  (Read 2197 times)
Offline luckson317
mk1 gti
« on: 09 February 2008, 21:54 »
Hello there, my mk1's radiator fan has stopped working and also no heat comes outa the heaters, just cold air. both pipes going to heater matrix are hot.
was wondering are these 2 problems linked or is this 2 problems and do you have any ides wat they are????? Thanks.
Offline [han]
  • Graphic Designer for Haribo
Re: mk1 gti
« Reply #1 on: 09 February 2008, 22:07 »
if you set the blowers to the footwell/winddscreen do they blow warm or cold?
side vents always blow cold.
if you also use the search function for heaters you may have some luck too. there are lots of little bits of info you'll be abel to find. Remeber to tick the search mk1 board tho as you'll get lots of mk2 info for sure!
Offline luckson317
Re: mk1 gti
« Reply #2 on: 10 February 2008, 14:26 »
the heaters are working fine now, but if the car is running for 5 mins or so then you put the hearters on, it just blows loads of smoke through the vents??? any ideas???
Offline [han]
Re: mk1 gti
« Reply #3 on: 10 February 2008, 20:32 »
care to share the problem with heaters for those who use the search function later?
is it definitely smoke? is something burning in your engine bay? is some lovely mk1 wiring spontaneously combusting?
it definitely isn't dust/muck?
Re: mk1 gti
« Reply #4 on: 11 February 2008, 13:02 »
could be a blown matrix, is it steam?
Offline luckson317
Re: mk1 gti
« Reply #5 on: 18 February 2008, 18:05 »
all sorted now, thanks for the help.
Offline [han]
Re: mk1 gti
« Reply #6 on: 18 February 2008, 19:34 »
care to tell us what it was?
it will help people who use the search function correctly if a thread is resolved.
Offline luckson317
Re: mk1 gti
« Reply #7 on: 24 February 2008, 16:36 »
yep, well i thought it was resolved, but i started work on it again today, aint had a chance before, and its worse, smells steamy, so am assuming its the matrix?
