Author Topic: Temperture guage not working  (Read 2400 times)
Offline billy_vw
« on: 09 February 2008, 18:37 »
Picked up my V5 today
Half way driving home (about 50 miles) i noticed my temp guage had not moved
Normally they sit smack on 90 in the middle.
How can i fix this?
Thanks in advance.
MK5 GT TDi
Offline richw911
Re: Temperture guage not working
« Reply #1 on: 09 February 2008, 18:45 »
Temp sender? You can do a check on the temp gauge itself with vag com i believe  :smiley:
http://uk-mkivs.net/forums/thread/980331.aspx
« Last Edit: 11 February 2008, 18:19 by richw911 »
Offline billy_vw
« Reply #2 on: 11 February 2008, 22:44 »
Rich
Thanks for the info,  :wink:
How different is a V5 against the 1.8T?
MK5 GT TDi
Offline richw911
« Reply #3 on: 12 February 2008, 18:21 »
Rich
I believe its in the same pipe and place as the 1.8T  :smiley:
Offline billy_vw
« Reply #4 on: 12 February 2008, 19:42 »
Using the car today and the temp gauge was working and a bit later it was'nt & then was OK again.
When it was working it sat dead on 90 as norm,
But i guess im better of replacing the temp sensor anyway  :undecided:
MK5 GT TDi
Offline richw911
« Reply #5 on: 12 February 2008, 19:45 »
I would check the wiring first TBH. Could be corroded terminals  :undecided: The temp sender is £25 and 60p for the clip and rubber seal.
Offline Mr Blue
« Reply #6 on: 12 February 2008, 22:29 »
If you have the black sensor then buy the newer green one anyway!
very common problem.
