Author Topic: Which Master Cylinder?  (Read 708 times)
Offline Classic16v
« on: 09 February 2008, 01:40 »
Hi guys
Just a quick couple of questions - my '91 spec 16v has decided it's time for a new master cylinder so I went on the GSF website and I'm confused.  Does anyone know if it's the 'BRAKE MASTER CYL-FAG 22mm' I need or the 'BRAKE MASTER CYL-22.2mm?' There's more than a tenner difference so I wondered whether it's best to have the FAG or the extra .2mm......
Also, is it a fairly straight-forward job to replace and can it be done from the engine compartment, or is it an 'under-the-dash' job?
Offline OakeyDoak16v
Re: Which Master Cylinder?
« Reply #1 on: 09 February 2008, 02:29 »
Just give them a call and tell them your engine number and get the right one. Get a garage to fit it though. Can cause problems. :smiley:
Offline paultownsend
« Reply #2 on: 09 February 2008, 10:15 »
i believe the 22.2 is the 16v size. sign up to  the edition38 vw website/forum and use your membership number to claim your 10% discount!
its easy to do too.well, easy enough for me to do!
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 09 February 2008, 20:04 »
Tis easy enough - been there and done that, too.
Make sure you get the brake bias valve open when you're bleeding up.
« Reply #4 on: 11 February 2008, 13:24 »
they're both the right one just a typo, the only difference is the price/quality.
