Car audio
bass problem
Topic: bass problem (Read 2201 times)
vdub_adz
GTI forum regular
bass problem
02 February 2008, 20:04 »
iv installed a sub with amp and power cap. works fine for about 20 mins then the bass gets deepper by its self and then cut the sub out. some times it comes back on and other times it dont. any idears???
Heyho
Here all the time
Re: bass problem
02 February 2008, 20:06 »
Sounds like the amp is going into protection.
Correct impedance? Gains set too high?
Chris 'N' Jen
Here all the time
MK4 2.0 GTi 8v in black (the best colour)
Re: bass problem
02 February 2008, 20:27 »
Agreed with the above.
Also, Make sure you have a good earth too as this will cause the amp to go into protect mode. Use sand paper if necessary to freshen up the earthing point.
Loose the powercap too, the system will work better.
Uruk Hai
Re: bass problem
02 February 2008, 21:39 »
^^^ As above, I wouldnt even consider a power cap untill your amp was well past 1000 watts
vdub_adz
GTI forum regular
Re: bass problem
03 February 2008, 15:20 »
the amp is 1200w and the sub is 1000w but i might run 2 1000w sub off it
Chris 'N' Jen
Here all the time
Re: bass problem
03 February 2008, 16:33 »
Quote from: vdub_adz on 03 February 2008, 15:20
Are they RMS figures or peak. If they are peak they mean nothing.
Still loose the powercap.
vdub_adz
GTI forum regular
Re: bass problem
Reply #6 on:
04 February 2008, 18:08 »
yea got rid of then power cap thanks for that. just needs some fine tuning now and ill b happy. thanks every 1
Chris 'N' Jen
Here all the time
Re: bass problem
Reply #7 on:
04 February 2008, 20:10 »
Good man.
Hope it all goes well
vdub_adz
GTI forum regular
Re: bass problem
Reply #8 on:
05 February 2008, 20:55 »
yea all seems to be goin great just need some time to fiddle about with it.
Car audio
bass problem
